Question about Sewing Machines
My tenshone is out of order.
The top thread is bunching on the bottom of the material.
  • Sewing Machines Master
  • 1,860 Answers
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Make sure the top thread tension is on the correct setting for the fabric being sewed.
9.Also could be a timing problem, and the machine would need to be checked.
Posted on Dec 03, 2014
Top threat bunching up under material
Either the top tension is too low, bottom tension is too high or you have not lowered the pressure foot.
Apr 14, 2015 | Sewing Machines
Fee motion quiltng thrad breaks on top and bunches onthe bottom
Likely the thread is catching somewhere. Of course there's no detail here and no machine model. Might be using a model that won't do FMQ
Aug 28, 2014 | Sewing Machines
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
