My remote is not a universal and it turns on my electric fire place every once in awhile
The tv sits on top of the cabinet where it is supposed to
    Master:
  • 373 Answers
Some manufacturers use the same remote signals because there are not an infinite number of them. Seems like you found this out. Nothing can be done except to maybe tape a "blinder" over the one unit so its remote must be aimed directly at it to function.
Posted on Dec 03, 2014
Our Toshiba TV (about 7-10 yrs old) is not responding to the on/off button or volumn controls sporatically to any of the remotes -- either cable/universal remote or the original Toshiba remote that came...
hi, usually its the infrared receptor that need to be replace, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit. good luck!
Feb 16, 2011 | Toshiba 36A40 36" TV
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
I need the Cox remote code for 32" Dynex TV
You can try Insignia remote codes, because both are BestBuy brands and this has worked before.
Jan 20, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
I have an electohome tv and am trying to program my rca universal remote- nothing is working...any suggestions?
These are generic RCA Universal Remote codes to control an Electrohome TV: 006, 011, 014, 027, 038, 061, 068.
Your specific model will have other additional codes. If these codes don't work, you could try re-posting with more information.
Many RCA universal remotes have a CODE SEARCH button. If yours does, here are the steps to search for the proper Electrohome TV control codes:
  1. Manually turn ON your TV.
  2. Press and hold CODE SEARCH.
  3. Press and release the TV button.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
Hope that helps.
Oct 15, 2009 | Universal Remote Control DIRECTV Universal...
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Ihave bought a GE universal romote control RM24948 and can not figue out how to set it up please help
Hiya this is how i got mine to work.Manually turn on the tv.Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Dec 15, 2008 | GE RM24948 Remote Control
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
Sony KP-53HS10 TV Infrared remote sensor problem
Hey, I called the local Sony Authorized dealer/repair. He said the little microprocessor inside the sensor goes bezark once in awhile......soo.......unplug the TV from the wall when you go to bed and then plug it back in the next morning. It worked for me. The little gizmo resets itself.
May 17, 2008 | Televison & Video
Ge 94948 universal remote instrutios for progaming t.v.
Feb 19, 2008 | GE RM24948 Remote Control
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
