Question about Jeep 2004 Grand Cherokee Laredo
My daughters abs and brake warning lights start to blink after she hit 15 mph+. at the same time the speedometer goes to zero mph and the odometer stops working. also at the same time when she turns o
Have no idea where to start. checked motor to body ground and battery ground
    Sergeant:
  • 286 Answers
ABS sensors are on each wheel, when a sensor is bad, it cannot sense the wheel turning, hence the light comes on,,, you can test each sensor with a meter while wheel is up and spun..
Posted on Jan 02, 2015
    Master:
  • 373 Answers
Go to Advanced Auto or similar and have them give you a free code scan. Then work on saved trouble codes.
Posted on Dec 03, 2014
Speedometer doesn't work
For speedometer related issues,the help links are provided below.Click the link below to go through its details :----
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
why speedometer not working? http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html----------- Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights warning indicator steady on dash and speedometer not working?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently? http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
This will help.
Thanks
Feb 14, 2012 | 1996 Plymouth Voyager
Which fuse do i replace for the speedometer?
For speedometer related issues, the help links are provided below. Click the link below to go through its details: ----
Speedometer works but odometer not working? http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html ----------- Speedometer runs backward?
This will help.
Thanks
Feb 04, 2012 | 1999 Ford Windstar
Where is the speedometer sending unit located
This will help.
Thanks
Feb 03, 2012 | 1993 Ford F250
The speedometer does not work
This will help.
Thanks
Feb 02, 2012 | 1998 Chevrolet S-10 Pickup
What does it mean when the speedometer goes out?
This will help.
Thanks
Feb 02, 2012 | 2000 Dodge Intrepid
2009 digital speedometer problem yamaha
This will help.
Thanks
Feb 01, 2012 | 2011 Yamaha XJ6 Diversion ABS
On a 2001 ford taurus what is the exclamatin point on the dash? The light comes on and goes off at times.
Hope this helps.
Item Part Number Description 1 — Instrument cluster 2 — Odometer reset shaft 3 — Air bag warning indicator 4 — RH turn signal indicator 5 — Charging system warning indicator 6 — Tachometer 7 — Low oil pressure warning indicator 8 — Brake system warning indicator 9 — Cruise control indicator 10 — Check fuel cap indicator 11 — Anti-lock brake system (ABS) warning indicator 12 — Check transmission indicator 13 — Odometer 14 — Transmission range selector indicator 15 — Trip odometer 16 — Theft indicator 17 — Low coolant indicator (if equipped) 18 — Safety belt warning indicator 19 — Low fuel warning indicator 20 — Fuel gauge 21 — Malfunction indicator lamp (MIL) 22 — Door ajar warning indicator 23 — Traction control indicator (if equipped) 24 — Engine coolant temperature gauge 25 — High beam indicator 26 — LH turn signal indicator 27 — Speedometer
Jun 05, 2010 | 2001 Ford Taurus
Car speedo & odometer sometimes work OK, other times not at all.
Most likely a speed sensor is going bad (most cars and truck do not use mechanical speedometer cables anymore) most sensors are located near the differential in rwd cars or near the drive shaft on the transmission. Best bet is to get a Haynes manual for your car to help locate the speed sensor. Remove it and take it to the auto parts store so you can visually compare it to the replacement. Install the new speed sensor and it should restore your speedometer and odometer.
Aug 19, 2009 | 1996 Honda Civic
Odometer inop and speedometer erratic over 50mph
Yes your speedometer, and odometer are controlled by your speed sensor.
May 20, 2009 | 1993 Saturn SW1
Jeep 2004 Grand Cherokee Laredo Logo
63 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
