Question about Look Cycling
Battery type on the fork
I look on google ..
Sachs City 125 fork oil type and capacity
Hi, Paul for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Sachs, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
sachs city 125 fork oil capacity Google Search
Sachs kitted front fork oil change
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Dec 28, 2017 | Sachs Motorcycles
Fork oil capacity?
Google is your friend in such cases.
Google
year make model fork oil capacity
When asking such questions we always need year make model because what might be good for a 1971 Kawasaki H1, might not be the same as for your 2010 Honda 50.
Apr 03, 2016 | Motorcycles
2001 FXD - What are the specs for front fork travel and how do I change the oil if needed in the fork tubes?
There are no specs for front fork travel. The forks will travel from full compression to full extenison. Use Harley type E fluid.
Sep 17, 2014 | Harley Davidson FXST Softail Standard...
How much oil in the front forks
2004 Touring Fork Oil Requirements
FORK MODEL TYPE and AMOUNT in OZ. ML IN. MM
Left FORK - All models except Road KingCartridge10.0 oz 295ML 4.21INCH 107mm
Road King Conventional 11.1oz 328ml 5.24inch 133mm
Right All modelsConventional11.1 oz 328ml 5.24inch 133mm
WARNING
Fork oil level in cartridge type forks is carefully measured from top of tube after pumping damper rod. Anydeviation from instructions can result in incorrect amount of fork oil. Incorrect amount of fork oil can adversely affect handling and lead to loss of vehicle control, which could result in death or serious injury.
Apr 14, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Steve
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
Buell Ulysses XB12X front suspension oil leak. 1) How much oil? 2) type of oil to be used? 3) How to replace oil seals?
The fork service is not for a novice. you can hurt yourself pretty badly with the compressed springs inside of the forks if you release them wrong. You need a copy of the factory service manual. You can download it if you google it. Otherwise it is strongly recommended that you take it to a trained professional.
Mar 07, 2011 | 2007 Buell XB12X Ulysses
How much oil do i put in my buells forks its a xb9r 2002
You need the factory service manual - it details the service of the forks. The air gap inside the forks requires you disassemble the forks to set it. the spring inside could pop out and hurt someone. Do a google search for the factory service manual
Oct 27, 2010 | 2002 Buell Firebolt XB9R
Help
hi
Go to google and type your Acer model no with webcam drivers it will give you list of letest drivers downloard and run that it will start working
Jul 16, 2010 | Acer eMachines 520-2890 Notebook
Cant find transmission forks for a 92 kx 250
Look in eBay, Google, local wrekers or dealers
Mar 23, 2010 | kawasaki KX 250 Motorcycles
Cycling Logo
44 people viewed this question
Top Look Cycling Experts
ray gallant
Bill Boyd
Donald Ayers-Marsh
Are you a Look Cycling Expert? Answer questions, earn points and help others
