Question about Exercise & Fitness
How do take the assement test - Exercise & Fitness
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Go to your library and get the book, which will explain all.
Posted on Dec 03, 2014
What is the List out the types of mobile app testing?
There are four types of testing that we perform here at Cleveroad. They are:
Basic development testing is a check after which there are no blocker and critical bugs. After advanced development testing, QA specialists detect all major bugs (if there are any) and developers fix them.
Basic and advanced testing are already included in the price of the development and customers dont pay for them.
After these basic and advanced checks, a quality product should not have any blocker, critical, major defects. But it can have few minor and some trivial defects.
Test automation is needed if the project is vast, complex and its development takes longer than 1,000 - 1,200 hours. If the test is needed, a QA engineer writes a test (code) that checks some big parts of the code, part of complex logic or a template scenario. This type of testing within a few minutes does the same amount of work as a manual QA engineer in a day. However, test automation is necessary only if the project is really big, otherwise, it will take more time than the manual check.
Enterprise testing is needed for complex enterprise systems, like banking or insurance software platforms. The product has to be perfectly debugged, as any defect can lead to a real problem. Read more in the article What is software testing and how do we run it at Cleveroad
Jul 08, 2016 | Advent Mobile Designs Visual Acuity Test
Trying to logon to select2perform.com/default?action=applicantlogin&key=18396184e . It states the url does not exists. This is to take the assement pre-employment test for sterling jewelers
How did you get to that exact URL? If it was linked from somewhere on the select2perform website, try to contact the website owner for assistance. Otherwise, go to their home page and try to get to that page through the site navigation.
May 17, 2011 | select2perform.com
I'm with a problem in Cherokee 5.9. appears on the iScan governor does not work, or governor out of range
I assume your talking about the govenor pressure sensor in the transmission,if you just had the tranny serviced by someone other than a jeep dealer, it is possible they used the wrong fluid,only atf+4 should be used,some places claim to use a friction modifier to make dexron fluid compatible,but it is not compatible.
An obd code would be helpful and the year jeep,and the problems you are having,the above answer is the most common problem when serviced with wrong fluid,while you may have other issue's without some more info I can't make an assement or offer advice.
May 31, 2010 | 2001 Jeep Grand Cherokee
Model DDG7189VTLWH heard a bang and drum stopped
I would say that you are probably right in your assement of the problem.
For more info on your problem, check out this tip...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 26, 2010 | GE Dryers
Washer is making a squeeling noise and smells of burnt rubber. I am assuming this needs a new belt but have not worked on washing machines befor
Yes, I think your assement of your problem is correct.
It does sound like a new belt is in your future.
Some are fairly easy to replace and others are a pain in the rear...
You may want to open your washer up and take a look at things before your tackle yours. The main problem with some washers is that you need to take so much apart to get the new belt routed correctly.
Do a search for "appliance parts" and then you can enter your model number in one of the sites that come up. You will then usually get exploded views of your machine and a parts menu.
Check a number of different sites as there is no one site that always seems to have the best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 03, 2009 | Maytag Washing Machines
I have a Neptune TL FAV9800AWW that will not finish the spin cycle. Says it's a circuit or something but all that is fine. Still will not empty with or without clothes.
Are you taking dc or UC errors to the display in spin cycle?
""Says it's a circuit or something but all that is fine."" Who made this assement?
""Still will not empty with or without clothes."" So I understand do you mean that you take no error codes to the display for this issue.?
The FAV9800AW has a different type of display then the FAV6800AW the machine I own. With limited.... no info on error codes I feel you are failing in spin cycle with either a "dc" error or a "UC" error. If so post back and we will go from there. Take a look at this owners issue and see if it similar to your issue.
Take a look through the Service Manual and see if this helps you identify error code types.
If you have water in the tube I can help you get into Service Mode and pump out the water. That will also let us know if the drain pump has failed.
Rich
Aug 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Exercise & Fitness Logo
37 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
