Question about Thor TH1500 - 1500 Watt Power Inverter
HOW DO I CHANGE A BLOWN FUSE FOR A THOR 1500WATT INVERTER?
How to change blown fuses
Ben, Power Inverters of different make and style use different fuses, I will post links for you to check out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacing Fuses Power Inverter
Homemade Circuit Projects How an Inverter Functions How to Repair...
Battery Sales Inverter Frequently Asked Questions FAQ
POWER JACK GRID TIE INVERTER REPAIR THE MOSFET MISHAP
Feb 26, 2016 | Electronics - Others
Why won't my panasonic inverter microwave will not turn on?
check when the fuse is blown,means inverter unit is faulty
Aug 05, 2014 | Panasonic NN-S251 Microwave Oven
2012 Thor Challenger 36FD; Auxiliary batteries went dead, tv recepticals and generation not kicking on. Charged batteries, but no change. Is there a reset button or maybe a fuse that I might need to...
Hi Thomas,
Why yes. I am offering you the direct site for IRV2. There you will find direct assistance for troubleshooting by phone in real time.
2014 Thor Challenger 37KT Owners iRV2 Forums
Here is the another. Not the same as above.
2014 Thor Challenger 37KT Owner Thor Forums
My assessment will be the automated transfer switch is not working. If the battery pack is below specified charged levels. The system has a protection circuit not to allow the transfer from the grid to isolation switch. When the charge is achieved to satisfactory levels. Then it will function.
It is possible you may have a shorted cell in one of the batteries preventing the charge to be successful. I would observe the water levels in each battery and every cell. When full there is a mirror like image in each cell designed to indicate the level. A run down battery will have very low levels at either end of it. The hydrometer is the best way to see specific gravity. When found then isolated you can remove from the series.
A blown fuse or tripped breaker protects the downstream equipment and the power control board.
There should be a shop manual somewhere in the RV. Customer service is available at the links offered. Fare. well.
Jul 06, 2014 | Thor Motor Coach Challenger 37KT RVs
The lights in my 2000 25ft Thor Tahoe slideout are not working how do I troubleshoot
use a meter to check the sockets for voltage either 110acv or, 12v dcv
if dcv it's is your batteries or inverter not supplying power check with a meter set on dc volts; if ac check your circuit breakers with a meter set for ac volts if these are fine then replace switches
Nov 26, 2013 | Thor Motor Coach RVs
Electrical problems with a 2001 Thor wanderer travel trailer. Several lights went out at the same time. the porch light, bathroom light and fan & 3 interior lights. I would like to get a wiring diagram...
There are no wiring diagrams for most travel trailers. Check all of your 12 volt fuses. If none are blown, pull each light fixture one at a time and look for loose/bad connections. You'll need to remove each fixture from the ceiling to get to the wiring behind it to check. Normally the lights will be run parallel meaning if you have a bad connection at one, the rest down the line will not work.
Aug 25, 2013 | Cars & Trucks
LT 3751 change the power board still no picture could it be a fuse and what fuse
Hello Jason:
Check the inverter board for blown fuses in will be a micro surface mount fuse, if it is blown then replace the inverter board assembly. The inverter is used to light the back lights of the screen. Also check the supply voltage from the power supply to the inverter should be between 12volts to 30 volts.
Also you if the inverter board checks ok , then your problem lies in the T-Con board this board is at the top to the panel under a shield.
Oct 14, 2011 | Norcent Technologies LT-2722 27 in. LCD...
Thor Invertor comes on then shuts off
I guess you have checked that the wattage of the power lift is lower than the rating of the inverter. It will need to be at least 25% less at a guess possibly more as the starting current will be a lot higher than the rated value of the motor.
Jun 03, 2010 | Thor TH2000 2000 Watt Power Inverter
No power-inadvertently left on empty GE je1160wmc
Hi. the inverter in your unit has failed. have it replaced asap. It is possible that the In-line fuse has blown as well. you can access this fuse by removing the cover. the fuse is locate din the inverter sector, in line with the power cord. If this fuse is not blown, replace the inverter assembly.
Aug 27, 2009 | GE Microwave Ovens
Thor TH1500 - 1500 Watt Power Inverter Logo
53 people viewed this question
Top Thor Electronics - Others Experts
Are you a Thor Electronics - Other Expert? Answer questions, earn points and help others
