Question about Kenmore Dishwashers
Looking to replace Kenmore 665 15879000 that is my mother's house. Just trying to find dimensions of dishwasher so I can avoid long drive there to measure, couldn't find answer on Sears website. Any
Can't find the dimensions of this machine anywhere. It is in my mother's apartment and am trying to avoid drive there to measure, no luck trying to google and I called Sears and they were no help, anyone know the answer or where to easily find, I could not find in owners manual.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
You don't need the size of the old dishwasher. What you do need is the size of the opening. Your going to put the new one in.
Posted on Dec 03, 2014
  • Kenmore Master
  • 932 Answers
Seth, the typical opening for dishwashers is going to be 34" in height and 24" in width. Some brands do make an 18" model but Sears sight should have mentioned that. Hope this helps!
Power went out and now dishwasher will not restart
Try unplugging your dishwasher and waiting 30 seconds, and then plug it back in. See if that helps.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 23, 2011 | Kenmore Dishwashers
Needing to replace Kenmore Built in Dishwasher model 587.1426582 Wanting to find specs so I know what options I have for replacement
95% of all dishwashers are the same dimensions and hook up all the same unless I misunderstood you can buy any
Aug 22, 2011 | Dishwashers
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
Control panel malfunction
for dishwasher part by part description for repairing internally with diagrams
http://home.howstuffworks.com/how-to-repair-a-dishwasher1.htm
Feb 26, 2009 | Kenmore Dishwashers
Kenmore Dishwasher 665.15789300 not washing, but gets water
The chopper blade assembly with in the pump housing is either clogged or broken, to get to it, you must remove spray arm and remove screws from filter housing. These are size 20 torx, inside sump are 2 more screws size 15 torx, after these are removed you can clean out chopper or replace it.
Feb 16, 2009 | Kenmore 24 in. 15782 / 15784 / 15789...
Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Jun 22, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore 587
You may try the rubber gaskets and fasteners that attach your heat element through the bottom of the dishwasher body. This is the only full penetration of the shell involving metal that I see. You could see these fasteners if you remove the dishwasher from its current position, rotate it clockwise on its side and see the two cheapo pressed metal nuts on threaded studs that have wires attached. These keep that black metal loop on the bottom (inside the washer) in place. Remove wires, unthread pressed metal fasteners, check heater element for the rust issue (replace if needed) and reinstall new rubber gaskets and fasteners. Hope that helps!
Oct 09, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
103 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
