Question about Solofill SOLOGRIND 2IN1 AUTO SINGLE SERVE COFFEE BURR GRINDER W/ ADAPTER 852932003167
The stop start buttons are frozen how do i fix
I tried emptying and cleaning but no luck
Ice maker stuck on crushed ice instead of cubes
most likely you have ice built up in the door or icemaker that has frozen hard easiest thing is to turn of fridge empty freezer leave door open to melt the ice remember to empty ice maker wash it out removing all ice ect. then when all is dry and clean start it up and see if that doesn't fix it.
Aug 20, 2014 | Kenmore Refrigerators
How do I fix my frozen e reader
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
My ipod classic 7th generation is frozen. the light is on but it doesn't respond to any buttons or the wheel. I tried to press the home button and the play button but it's not doing anything.
Hi! (: i'm not sure if this will work, but when my ipod did this, I left it in a cup of rice for a few hours, then I left it charging for a while until it turned on and showed the home screen. If this doesnt work, try calling apples technicians on their website! They can help sometimes..
[Also, yahoo answers might have a better solution] Good luck!
Dec 04, 2012 | Apple iPod classic 7th Generation
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Fridge part freezes up , lost manual cant work out what the on/of switch is meant to do?
If this was my fridge
1 I would give it a soft kick with my right foot/ your left
2 nothing happens
3 empty the fridge
4 push the off switch
5 should the unbeliveable happen that the frozen part would start to melt
6 then I put some boiling water in a wash basin in the fridge and a few towels on the floor-we don´t want water on the floor, do we?
7 when all the "frozen places" have disapperaed .
8 clean the fridge´s insides
9 push the on button and close the door properly
10 wait for 30 min open again and see if the places that are supposed to be frozen arn´t frozen
11 if they are put the good things back into the fridge
12 and have a good cup of coffee
Good luck
kollagunn
Jun 04, 2011 | Freezers
On my Epson Stylus DX7450 printer ,underneath the stop button is 2 wee lights 1 with a page beside it and the other with a drop(like an ink drop) beside it.Its an orange light that its on on the 2nd...
Hi, one of your ink cartridges are empty, to check which cartridge needs replacing press the stop button, the carriage will move across to the left and sit below a pointer. This will point to the empty cartridge.
Press the stop button again, the carriage will move across either to display another empty cartridge or to the position to allow you to change the cartridge.
This can also be checked using the Status monitor software on the PC.
Nov 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Epson CX7450 Black Ink Won't Work...
I was having the same problem. This fixed it:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Feb 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Player frozen, green light on
i had my GFs mp3 player and it was flashing green light, not solid, but still was frozen and couldnt even bring it up on my computer after plugging in the USB cable. but i just tapped the reset button on top right side, and it stopped flashing and turned off. i turned it back on and started to play normally. not sure if it will be the same since the light situation is different, but the reset button worked for me. good luck
Jan 28, 2009 | Creative Labs ZEN Stone MP3 Player
Solofill SOLOGRIND 2IN1 AUTO SINGLE SERVE COFFEE BURR GRINDER W/ ADAPTER 852932003167 Logo
69 people viewed this question
Top Solofill Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Solofill Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
