Question about BORND M510S Wireless Keyboard & Mouse Combo White Black
Is there a manual available?
How do you set up the email key?
    New Friend:
That bornd dot com link is totally useless for product support; it contains only sales promotional material in broken english and in chinese writing.
Posted on Jul 31, 2015
You can find a lot of informations at this link: http://www.bornd.com/en/keyboard/wirelessdesktop/m510s.html regarding your keyboard and mouse combo.
Posted on Dec 15, 2014
I have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
How can I do to type sign @?
The Nakajima AE-740 has a secondary set of characters on the keys in the upper right. I suspect that this alternate set is currently enabled. Do you see a Downward triangle above KBII? If so, press and hold the Code key and then press 5. Release both keys and check if the Downward triangle has disappeared from the display. Now, you should get an @ when you press Shift and then type 2.
ManualLib has the manual for the AE-740 available, http://www.manualslib.com/manual/455216/Nakajima-Ae-740.html . The information on toggling the alternate key usage is on page 43 of the manual.
I hope this helps.
Sep 01, 2014 | Nakajima AE-740 Typewriter
How do I change the Language from Spanish to English? the manual is no help....
Under phone settings, the third menu item from top (3) is for language selection. Good luck.
Jan 21, 2014 | Blu Diva X Mobile Phone
Where is the "do not disturb" setting on a Samsung Rugby?
This is related to the Push to Talk function:
PTT Settings
1. In Idle mode, press Menu -> PTT and press the Select soft
key or the key.
2. Select PTT Settings and press the Select soft key or the
key. Choose from the following options:
• My Availability: this option allows you to change your Availability
status. Use the Up or Down Navigation key, to highlight Do Not
Disturb or Available and press the Select soft key or the key.
You can find the manual here:
http://images.comparecellular.com/phones/1362/samsung-rugby-ii-user-guide.pdf
Oct 21, 2013 | Samsung Rugby SGH-a837 Cell Phone
I have lost manual for Samsung blackjet sgh-1607. My phone number appears as "private number" when call somebody. I want to display my phone number to others when getting my call. please advise...
From the Home screen, press the Start softkey. Select Settings > Phone . Use the arrow keys to navigate the menu. Then select the Caller ID sub menu. You can set the phone to show or hide your phone number to everyone, no one or your contacts. Press Done to save and exit the menu.
A pdf of the manual for the BlackJack SGH-I607 is available here: http://www.wireless.att.com/support_static_files/manuals/Samsung_BlackJack.pdf . The brief description starts on page 61.
I hope this helps.
May 15, 2011 | Samsung Blackjack SGH-I607 Smartphone
Yesterday purchase HTC Wildfire A3333 but cannot use as manual to set up not available, so unless you can help me it is going back!!
I have set up one private email account that works and two other work ones that dont. How do I delete an email address?
Aug 24, 2010 | Cell Phones
How do i set up emails on the nokia n95 8 gb
Tap the Nokia Menu Key and choose Messaging. Scroll down to Mailbox and click. You will be told ‘no mailbox defined. Define now?’ Choose Yes.
A wizard starts which walks you through the process. First choose Start with the left selection key. Choose your mailbox type using the scroll key and clicking to ensure the correct one is selected with a dot to the left of its name. If you have webmail or an email address from your Internet service provider, choose POP3. Click Next.
Type in your email address. Use the star key to pull up a symbols list so you can choose the ‘@’ symbol and the 1 key for the dot. Choose Next.
Enter your incoming mail server then choose Next and your outgoing mail server then choose Next. Now choose your ‘access point’. The choices will depend on which operator you are using at the time and you may need to ask your operator for the right information. You can get the phone to ask you every time if that might be useful. Make your selection then choose Next.
Now give this mailbox a name. Make it meaningful, something like ‘Gmail email’ if your email provider is Gmail, for example. When this has been entered choose Finish and you will be told ‘Mailbox setup complete. Settings can be viewed and edited in e-mail settings’. Click OK.
Personalise the settings
Now you need to tell the Nokia N95 how to behave when it is picking up and creating email.
When viewing the messaging main screen scroll to the mailbox you just set up and click it to open it. Now choose Options then E-mail settings. From here there are several sets of settings to make.
- Choose User settings.
  • In the space under My name type your own name. This will be used to identify you instead of your email address when the recipient device supports that.
  • Under Send Messages click the scroll key to choose between sending messages immediately they are created or at the next manual connection
  • Under Send copy to self click the scroll key to choose between copying yourself in to all emails sent or not
  • Under Include Signature click the scroll key to choose whether you want to include a pre-defined signature on all emails. If you choose yes, you are asked to define the signature now.
  • Under New email alerts click the scroll key to choose whether you want the N95 to tell you when new email has arrived. This is useful if you have chosen to retrieve emails automatically – see ‘automatic retrieval’ below.
- Choose Retrieval settings.
  • This is where you tell the phone how much of each email to retrieve. You might want to retrieve less if you think you will end up spending a lot on connection time. The choices are; to retrieve headers only, to set a size limit on downloads, or to retrieve messages and their attachments.
- Choose Automatic Retrieval.
  • If you need to get your email regularly then you can set up the phone to pick up messages at regular intervals. Choose Disabled if you want to pick up email manually
- Choose Connection settings.
  • Here you can change any of the basic email settings such as incoming and outgoing email servers and can give the phone your login password
Check out our Internet Settings page here
Oct 31, 2009 | Nokia N95 Cellular Phone
Same problem on 3110c
DEAR THERE COULD PROBLEM IN UR NOKIA PROFILE SETTINGS,I WOULD SUGGEST U TO FLASH UR PHONE OR WISIT NEAREST NOKIA CARE CENTER TO DOWNLOAD NOKIA PROFILE SETTINGS
Jun 30, 2009 | Nokia 5310 Cellular Phone
Manual
MANUAL:
http://www.tagheuer.com/_documents/manuals/EI2254_en.pdf
May 28, 2009 | Tag Heuer 2000 Classic Multigraph...
Need encryption code...
here is a trouble shoot guide for your problem. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Mar 03, 2009 | Dell TrueMobile 2300 Router (000001)
BORND M510S Wireless Keyboard & Mouse Combo White Black Logo
220 people viewed this question
Top BORND Computers & Internet Experts
David Payne
David Payne
Are you a BORND Computer and Internet Expert? Answer questions, earn points and help others
