My gbox mx2 has no sound how do I get the sound to work again?
Check volume, on tv as well as gbox, unplugged the device,
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
The system might be fused or if you have animals they could have knocked the wires out..
Posted on Dec 03, 2014
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    Download jailbreak free
    Is this program good enough to jail break my gbox mx2?
    Jan 05, 2014 | Apple iPod Touch 8GB 32GB 64GB 3rd...
    Volume problem
    I would try going into the settings and seeing if any Audio Limitations are set.
    Sometimes this cannot be controlled due to the devices connected to the TV set.
    Also try to cold boot the TV by unplugging for 5/10 secs and plugging it back it.
    Apr 28, 2012 | Televison & Video
    Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
    1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
    May 18, 2011 | Toshiba 32A33 32" TV
    What kind of gear oil goes in my 5sp 94 4x4 deisel 6.5 i know that the transfercase shares the same oil so whats the weight of the oil
    Are you sure about gbox and xfer using same oil? I only know the NV4500 gbox and NV241 or BW4401 xfer setups. In both cases there is an oilseal on the xfer input shaft, which is known to fail, resulting in the gbox oil level dropping. This causes expensive damage. NV4500 uses ONLY!!! CASTROL SYNTORQ LT or GM12346190. Xfer uses ATF.
    Nov 16, 2010 | 1994 Chevrolet Silverado 2500
    When i plug in my logitech headset whitch is usb plugin the music plays go over the headset.But when I unplug the headset music does not play over the speakers.How do I fix this so it playes over my...
    Start - Control panel - Sounds and Audio devices - Click on the "Volume" tab. Check that the device volume is included in your volume control (Advvanced - Options - Properties)
    Also check your speaker Volume and Settings.
    May 16, 2010 | Microsoft Windows XP Professional
    No sound on Logitech Z Cinema 2.1 speakers.
    1. Check Output cable properly connected to the computer in Green socket.
    2. Check computer Volume Balance.
    - go to start- control panel-sound & game controller
    - check ur volume mute/unmute, volume all balance
    3. check sound drivers/update driver
    - go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
    - Then Scan in device manager. it will automatically install again.
    4.Then check output volume.
    Feb 01, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
    Televison & Video Logo
    44 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
