Question about Capresso Jura Impressa X7 220v
My jura x7 keeps going into rinse mode when steam or anything other than standard coffee is selected. it will do coffee but not the milk bit and when steam is selected it goes for a second and clicks
Changed water pump and brew unit all working but the system won't seem to give me steam or any milk related products
My jura X7 system is rinsing with milk. When pressing the rinse button, the machine is drawing milk to rinse instead of water??
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
Aug 15, 2013 | Jura Capresso Impressa X7 Espresso Machine
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Jura impressa X7 will no longer pull cleaning fluid, dispense milk or steam
I would like to know more in order to better understand. When any of the steam functions are selected do any errors display? Also, does steam come up through the machine from inside? It could also be that a solenoid valve (electronic valve that can operate flow) may be bad. It almost sounds like the problem you have may be coincidental with the hose incident and now it's a little harder to diagnose.
Apr 10, 2012 | Jura Capresso Impressa X7 Espresso Machine
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Where do you put the cleaning tablets in a jura impressa x7-s?
add a capfull of the cleaning fluid to a litre of water, insert milk tube and request cappuccino clean from the cleaning button...icon of cleaning tablet surrounded by water droplets, second row second button from lefthand side...then follow screen instructions to step your way through the cleaning selections with +and - buttons.
I keep the cleaning fluid held high to allow it to continue running after the cleaning action.
Remember to run clean water through the pipes using the same method above.
Google x7 manual and you can download one of many copies online.
May 05, 2009 | Jura Capresso Impressa X7 Espresso Machine
Capresso Jura Impressa X7 220v Logo
43 people viewed this question
Top Capresso Saws Experts
Tom Chichester
ray gallant
Are you a Capresso Saw Expert? Answer questions, earn points and help others
