Question about Sander Tools & Hardware - Others
1/4 sheet sander with dustbag, the first few times i used this the dustbad worked great. now it seems to be spitting the dust out the front, and yes i used the punchure tool. and i tried tapping to get any blockage cleared.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Sounds like after you cleaned the unit you put the dust bag in backwards. Try turning it around and see what happens.
Posted on Dec 03, 2014
Having lots of drywall dust, vacuum cleaner is connected and hose is having suction but sander is kicking dust all over the place. Can you help .
Wet some old bed sheets and lay it on the floor where you are sanding.Sand by hand.Using a power sander will not only damage the wall;but will also damage both the vac and sander
Jan 21, 2018 | Vacuums
Can the platen on DW411 be replaced
Yes it can be replaced. If you go to www.ereplacementparts.com, you can look up your sander and find the parts you need. You can buy the parts there or get the part numbers and search the web for pricing.
Dec 03, 2012 | Dewalt DW411 quarter - sheet palm grip...
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
Belt sander 3x24 Porter Cable
Try some "Simple Green" concentrate cleaner, or the "Simple Green" barbecue cleaner in a spray can to clean the roller. Should not use a dremel as you probably know now because of damage.
Another good idea is to blow out the tool after each use with compressed air. An air compressor is a great tool for a lot of things!
May 30, 2009 | Porter Cable Cable Tools 3" X 24" Belt...
Ryobi half-sheet orbital started screeching - any way to lube it?
Take that sander apart and you can oil the roller externally with a good lubricant not a gel like substance but oil that is made for things to move better. Doesnt have to be heat resistant after you have oiled both sides with the belt off. Then turn it on and let it mix. You may have to do it a few times to get it to work well again
Apr 26, 2009 | Tools & Hardware - Others
I have a d26441 sander. No instructions. Are the
Do not break anything. Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom and download a user manual for the tool. It should have come with what is called a punch plate to perforate the sandpaper for dust pickup (such as it is) Go there first and you will find everything that you need to use the tool
Mar 09, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
Top Sander Tools & Hardware - Others Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
