Question about Microwave Ovens
How can the Number plate be fixed? It needs "massaging" with a napkin before it registers and starts the microwave.
Have cleaned the number plate and that doesn't help. Is this fixable?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Try unplugging it to clear its memory that might help.
Posted on Dec 03, 2014
I has microwave kenmore glass plate is broken,but I don't know what size I can get ,i look for part numbers I only see this number p no 3850w030g is its correct number?
The correct model number is located on the appliance data plate. It's usually located on the door jamb (built-in) or back or bottom (for a countertop unit). Sears uses a 123.456789123456 type of designation (where the first three numbers/letters are the manufacturer. The data plate will clearly state "Model" followed by the number.
Dec 27, 2017 | Kenmore Microwave Ovens
Small metal-like plate against wall smokes when I try to use the microwave. Bought it last year. Afraid it will cause a fire so I don't use it. Pregnant with twins..need my microwave.
Shelley,
That is actually a mica plate and that can be replaced. I would suggest trying to find an appliance repair store near you and give them your make and model number of your microwave and they can probably order the part for you. Worst case scenario would be that you might have to order a piece larger than you need and you would have to trace out your old one onto the new one and cut it out yourself. It is not hard to do. What happens, is food grease gets splattered around during cooking, and it can get built up behind that plate and it will start to smoke after a while. You could try removing the plate and cleaning both sides real well, and if it has not charred the plate on either side, you might be able to get by with putting it back in. Hope this helps!
May 19, 2015 | Microwave Ovens
I NEED A GLASS PLATE FOR AN OLD EMERSON MICROWAVE. THE NUMBER ON IT IS MW8775W. DO YOU KNOW WHERE I COULD OBTAIN A PLATE THAT FITS THIS MICROWAVE?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Feb 27, 2011 | Emerson MW8775W Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
The glass plate in my microwave shattered and I need to get a new one.
Go to "sears.com", click on "Parts Direct", another page will be displayed, enter you model number (usually found just inside door of microwave), select cabinet and you should see your glass plate listed, scroll down to required number and then you will see the part number. Copy and paste that number into search engine and look for best price or just buy from sears
Oct 17, 2009 | Microwave Ovens
Need glass plate for 24 year old Goldstar microwave model ER4010
The original part number was 2B70335A then it was 30QBP004, but these are no longer available.
Jan 14, 2009 | Microwave Ovens
JVM1871sk04 GE XL 1800 Microwave
PS50009 is the part number for your glass plate that will cost you $60.00, go to partselect.com, simply put the part number... and place an order ....you know what to do next...
cheers pls mark my solution
Nov 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung Microwave repair
This would be the turntable coupler, and you can get it here. The best way is to search by model number. If by chance you don't find it, call them at the number on their site.
You need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 24, 2008 | Samsung MD800SC Microwave Oven
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
GE Spacemaker XL1800 Microwave
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
