Question about Kenmore Dryers
Will not start
Model 80 checked electrical it is fine
  • Kenmore Master
  • 744 Answers
Hello Bernie;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number, so I can not give you the correct part numbers and cost.
I am going to show you through pictures where the 3 primary components that will prevent your dryer from starting.
1.) Door Start Contact Switch.
Open the dryer door. There is a small round plastic component. Push in - did you hear a click? If not you may have a bad switch.
Open the top of the dryer. There are to spring clips, one on each side that you need to push in on and lift. You can use something like a small spatula.
There are two wires on the switch. Remove the wires. If you have a multi-meter, set the meter on the lowest Ohms. Put one meter lead on one switch contact and the other lead on the other switch contact while pushing in on the switch button. You should get a reading of '0' Ohms. If not the switch is bad. If you do not have a multi-meter, Carefully, with power on turn on the dryer and momentarily touch the two wire leads together to see if the drum turns.
2.) Thermal Fuse.
The thermal fuse may be blown. In the back of your dryer is the thermal fuse.
Use your multi-meter as described above to check the thermal fuse. If you do not have a multi-meter, with the unit unplugged use 12 gage wire to jump the connectors. Plug the dryer in and start the dryer momentarily.
3.) Thermostat.
The only way to check this is with a multi-meter.
4.) If all three of the above components check out ok, then you need to check the motor drive pulley contact switch. After you have accessed this arm switch, press up and down on it. If you do not hear a click then it is bad and needs to be replaced.
Posted on Dec 03, 2014
My 1991 Audi 80 will not start, engine cranks
Sounds to me like you may have left the air temp sensor or something electronic disconnected - Distributor - MAF sensor - go back and check and make sure that there's not an electrical pigtail somewhere hanging off - a vacuum leak wouldn't keep it from starting unless it were major - and your AUDI is mechanical injection I think - so fuel pull isn't a problem - check those connectors - let me know??? Thanks
Aug 21, 2009 | 1991 Audi 80
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Dryers Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
