Cars & Trucks Logo
Terry Monday Posted on Dec 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program remote control 28070T
TRYING TO PROGRAM MY REMOTE CONTROL FOR WESTINGHOUSE MODEL 28070T
Frank Topel
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 121 Answers
  • Posted on Dec 03, 2014
Frank Topel
Expert
Level 2:
New Friend:
Cheetah:
Answers
121
Questions
0
Helped
54392
Points
364
What type of machine is this?
How can I program a key fob
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS Transmitter Programming No Tools Required In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver.Up to 4 transmitters may be programmed Important Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver
Keyless entry does not work
I would suspect the remote is defective.
2helpful
How to program keyless entry remote for buick lacrosse?
I own a 2007 Buick Lacrosse, but I imported it to Paraguay, South America. Now I bought a new Engine Start Keyless Entry Remote from Amazon, but here we do not have any GM dealer to program the unit.
I really need help to program the keyless remote control, I will appreciate very much your help.
9helpful
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Hope helps.
2helpful
2answers
2003 remote control for 2005 van?
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important
Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems. IF THIS WAS HELPFUL,PLEASE RATE,THANK YOU
2helpful
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
1helpful
2answers
New alarm fob for pt cruiser not coded to car (correct serial numbers)
Programming
When
Remote control added or replaced. System malfunction.
How
Switch ignition ON. Press and hold lock button Fig. 1 [2] for approximately 10 seconds. Keeping lock button depressed, press and hold unlock button within 10 seconds. Programming mode activated (acoustic signal will be heard). Proceed as follows: Release lock/unlock button. Complete the following within 30 seconds: Press lock or unlock button of first remote control. Correct programming indicated by a single acoustic signal. Press lock or unlock button of second remote control. Correct programming indicated by a single acoustic signal. Repeat above procedure to program any remaining remote controls. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 remote controls can be programmed.
4helpful
Programming a 1995 toyota avalon key fob
To program a remote... note that you must not delay more than 10 seconds between any of the operations.
Driver's door open, all other doors closed, key removed from the ignition switch.
Insert key into ignitions switch, then remove it.
Press LOCK then UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times.
close and re-open drivers door.
Press LOCK and UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times
Insert Key into ignition switch.
Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code while erasing the original codes. three times to check how many remote transmitters are currently registered, or 5 times to erase all registered codes.
Remove Key from ignition switch.
System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. It will lock and unlock one to four times slowly, to indicate the number of remote transmitters registered if you chose option 3.
Press and hold remote transmitter LOCK and UNLOCK buttons at the same time.
Press LOCK remote button for 1 second: System should now lock and unlock vehicle once to confirm, twice to indicate registration has failed.
NOTE: to exit programming mode, close drivers door or insert key in the ignition.
NOTE: a maximum of 4 remote transmitters can be programmed
2answers
Programming nissan Quest Remote control
I have a used Nissan Quest 1999 that Remote Control does not work . How can I program it?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
