Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
How do I remove a Viking side by side refrigerator from the wall cabinet it is in?
  • 47 Answers
Hi, you need an installer to uninstall the unit as its bolted to the wall so it will not tip over from it being top heavy. Disconnect your water line under the unit of connected, there are levelirs that are raising the wheels off the floor. Call a local built in fridge installer and go from there.
Posted on Jan 16, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
There are adjustable wheels on front. Jack up front enough to grab the frame and pull out slowly. Be careful if you have water line for ice maker.
Posted on Dec 03, 2014
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
Refrigerator has strong chemical (like alcohol) odor....side-by-side GE. the smell is in both sides and has contaminated all of the food. i have thoroughly cleaned the appliance. What is this?
The alchohol type smell is definetley a refrigerant leak in my opinion unfortunatley if it is in your cabinet it becomes a nightmare to track the leak. The leak if it were in the cabinet would be from the small capilary line that you can see from either taking the lower panel off the back of the machine or removing the rear panel on the inside rear wall of the freezer. I would suggest you call a compressor repair technician to perform this repair. If you have any further questions message me back. Thank you
Rick
Jan 15, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How do I remove and replace the water filter in my side by side?
I'm not familiar with this particular model, but often they are an 'in-line' cylindrical cartridge type of filter on the end of the mains water supply to the Fridge/freezer - pull the cabinet out from the wall and look behind to see if you can find one.
May 18, 2011 | KitchenAid KSCS25FKSS Side by Side...
Stainless is scratched....we would like to replace with a wood covering made for the refrigerator that can be painted color of wall cabinets dimensions 36 inches x 67 1/4 inch
There are wood refrigerator cover options at applianceart.com. Not sure if it will match your cabinets, but I saw that they do custom ones too.
Sep 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
We purchased a new KitchenAid Side by Side Refrigerator Model # KSRG25FVBL01 that makes a loud knocking noise accompanied by rattling from the date we purchsed. We are getting runaround in getting it fixed...
The knocking noises heard from the Freon moving through the sealed system are perfectly normal and usually do not last long. Since the evaporator coil is mounted in the freezer section, the noise is usually louder there. Some people say it sounds like marbles knocking together.
Refrigerant (Freon) moving through the system can cause a vibration/rattling, especially as the compressor first starts up.
  1. Vibrating from top of cabinet Remove, rearrange or pad any stored items atop the refrigerator such as houseplants, coins, pens, etc.
  2. Vibrating from back or sides of refrigerator Move refrigerator away from water line in the rear or away from walls / cabinets along the side of the cabinet. Refrigerators with a static condenser on the back require a rear clearance of 3 inches across the top of the condenser.
  3. Vibrating from the bottom of refrigerator Level refrigerator so all 4 rollers / feet rest solidly on the floor.
    Hope this works.....
May 01, 2010 | KitchenAid (KSRD22FKST) Side by Side...
My 3 year old Viking refrigerator starting making really loud noises today...what can I do avoid a repair bill???
If the loud noises sound like a fan blade hitting ice you have a defrosting problem.
You can try unpluging the unit removing the contents then doing a manual defrost with a fan blowing into the unit for a bit over 2 hours then restarting the unit to see if the noise has ceased.
If it is a noise associated with the compressor you can try pushing it gently in it's floating mounts to try and reposition the unit so the vibration absorbers are functioning properly again.
Lastly if it is the condensor fan making noises break out the crevice tool and remove the lint from the coils. If you have pets this is very important.
Sadly if the problem repeats in less than a week after doing the above the dreaded serviceman / repair visit will be required to islolate the cause or source.
Vikings' website:
http://www.vikingrange.com/consumer/footer/contact_us.jsp?id=cat50013
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Viking 42 in Built In Professional...
The freezer isn't defrosting, and as a result the ice is building up inside it, and the temperature isn't as low as it should be.
I do not really do that much on the viking brands but you are having a defrost problem which is typical in all refrigerators. The problem will be 1 of 3 things. 1st defrost timer, 2nd defrost t-stat which is located on the coils in the freezer section behind the freezer wall and 3rd the defrost heater. Sorry I couldn't be of more assistance but 1 of these is your problem For temp fix so you have your cooling back you could remove the back wall of the freezer and using a hair drier deice the unit down so air can flow properly again. Good luck. Rick
Feb 24, 2010 | Viking 42 in Built In Professional...
VIKING FREEZER FROST BUILD UP
DEPENDING HOW OLD THE UNIT IS YOU MIGHT HAVE A BREAK DOWN IN THE INSALLATION ON THE SIDE WALLS OF THE APPLIANCE.ALSO CHECK THAT THE DOOR SEALS ARE SEALING OK IF ITS A BREAKDOWN WITH THE INSALLATION THAT MIGHT BE A COSTLY REPAIR BUT GET A TECH TO GIVE ADVISE.GOODLUCK.MOHAMED
Sep 15, 2008 | Refrigerators
FREEZER NORM TEMP. FRIG. 60 DEGREES.
DEFROSTED COIL WITH HAIR DRYER BEHIND FREEZER WALL BELOW FAN,
REPLACED FRIG. THERMOSTAT.
Aug 11, 2008 | Maytag 21.6 Cabinet Depth Side by Side...
Viking beeping
do you notice alot of ice builup on the freezer back wall? if so you need to defrost it and more than likely replace the defrost terminator. make sure you remove the back panel and use boiling hot water to remove the ice( i normally use a coffee cup) part # 10442407 ONLY USE VIKING PARTS) others may tell you to use whirlpool or some other but DON'T
Mar 29, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
97 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
