Question about Thule 2006 Toyota Tundra - Double cab - Xsporter Truck Rack
How do I check relay dimmer and light relay. thanks joe s.
How to find out is the relay bad? lights work on dime not bright? thanks Joe s.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 22 Answers
Use a test light at the bulb plug in. Try it on high beam and low
Posted on Dec 03, 2014
Corolla2010 bright lights quit working
Most likely the diming relay is bad, or the switch on the steering collum is not working. It's possible the connections at the relay are bad. or it's ground to the bodywork is bad or rusted or corrosion. to find the relay follow wire from head light back to the relay.
Mar 20, 2015 | 2010 Toyota Corolla
Can someone tell me where the headlight relay is located on a 1999 Ford Expedition
Low beams would be through the dimmer switch on the column. If your relay was bad you would have neither low or high beams.
Mar 01, 2015 | 1999 Ford Expedition
Why will my dim lights on my 2006 chevy trailblazer not work only the bright
Your low beam relay might be bad or the dimmer switch is faulty. A possible cut/corroded wire could also be to blame.
Jan 13, 2013 | 2006 Chevrolet Trailblazer
1998 toyota corolla dash and shifter lights out fuse and relay good
sounds like you have a bad panel dimmer control. try turning the control from bright to dim very fast a few times then slowly, do this in a dark area or at night with the headlights on, you should see a flicker of light occasionally. If you don't see any light then it could be either the headlight switch or the dimmer control, if you DO see any light, then it's your dimmer
Nov 14, 2011 | 1998 Toyota Corolla
In have a spst 12v lighted toggle switch that i use in my hobby i cant keep it lighted i use it to shut off the power to sideing tracks on my ho model train. new to wireing it hase 3 blades pos acc neg ....
Hi Gi Joe. I am assuming that you are wiring this on the DC side of the train power supply. So, the negative from the power supply goes to one of the rail connections. From this run a wire to the negative of the switch. The positive of the power supply runs to the positive of the switch. The ACC of the switch runs to the positive connection of the rail. The switch breaks and makes the positive connection to the rail. The power supply is 12 volts I also assume. The light should now go on when the switch is set to ON and suppling power to the rails. The negative of the power supply provides a return so that the light goes on and the train can run.
Please leave a comment if this helps.
Joe
Jan 26, 2011 | RTO Spst Toggle Switch
I recently installed a aspire rf9534ds dimmer and a 9542ab accessory dimmer in my home. Everything works, but on the accessory dimmer the amber light stays lit all of the time. On the master switch the...
I was reading one of the Lutron Maestro accessory dimmer manuals yesterday, and it showed how that little light was also a fuse that you could remove to turn off power. I didn't read exactly why it has that fuse.
You might check your manual to see if that is the same feature on your accessory dimmer.
Oct 23, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
The headlights only work on Bright. The dim
If the low beam head light relay is fine,and the dimmer switch checks out fine,then look at the out put wire from the dimmer switch to the head light relay,check for voltage,then check the relay to see if it energizes.Then follow the wire(out put)from the relay to the head light.Now if power from the dimmer is getting to the relay,but the relay is not energizing,look for a bad relay,or bad relay ground wire.
Oct 30, 2009 | Buick LaCrosse Cars & Trucks
Dimmer lights will not come on but the bright light works. I have change the headlights, lightswitch, dimmer switch, what esle can I check.
To keep the switch from arcing and wearing out, they use a relay. The dimmer switch turns the relay on and off, so does not use as much current. The relay is a small plastic box plugged into the fuse box, along with several other relays.
Oct 27, 2009 | 1994 Jeep Grand Cherokee
2002 Grand Am GT Headlights seem dim , fog lights dont work
Check at the headlight sockets for a bad ground.
Mar 02, 2009 | 2002 Pontiac Grand Am
NO headlights when turn ed on but lights will work if you hold th
Are these interior lights our the headlights? If it is the interior lights, you should pull the dimmer switch and check for a bad connection especially the ground connection on the back side. If that is okay, you may need to buy a new switch. If it is the headlights, check for a bad relay.
Jan 25, 2009 | 1993 Dodge Dakota
Thule 2006 Toyota Tundra - Double cab - Xsporter Truck Rack Logo
101 people viewed this question
Top Thule Boating Experts
Tom Chichester
Richard Warren
Richard Warren
john cordey
john cordey
Are you a Thule Boating Expert? Answer questions, earn points and help others
