Question about Air Tools & Compressors
My ingersoll rand compressor 825 shut down when loaded. What can be the cause and how do i fix it.
Serviced the fuel pump and replaced all filters yet problem continue
louislevel_2
  • 374 Answers
SOURCE: When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Posted on Apr 28, 2009
  • 2976 Answers
SOURCE: My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Posted on Aug 08, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 1388 Answers
SOURCE: compressor runs loaded continuously even in low/no demand periods
Each compressor should be checked several times per year as to length of time it takes to fill an empty tank to set pressure. This will provide chart of performance / efficiency. I believe that compressor #2 is not running to full capacity. If compressor # 2 is suffering from leaking valves or headgasket the head and air discharge temp will higher than compressor #1. Good luck!
Posted on Oct 18, 2009
compman66
  • 169 Answers
SOURCE: 1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Posted on Jan 09, 2010
Testimonial: "Thank you very much for responding. It was a little low on coolant. The comp. oil level was fine. I changed the fuel filter and the prob is gone"
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean
compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
Jun 24, 2014 | Ingersoll Rand Stationary Air Cooled...
My air compressor will crank and run for 7 to 10 minutes and then die just like you turn the key off.
well you didnt mention what year or model number you got but some of the better IR compressors have a fuel saver mode that if they don't sense any change in load for like 15 minutes they shut off could be what your seeing , or could also be a safety sensor on the seperator tank not seeing any pressure build up (bad or damaged sensor?)
Apr 15, 2014 | Ingersoll Rand Air Tools & Compressors
Air compressor starts and builds air then idles and when it goes to rebuild air it dies
if your saying it wont recover from idle down mode back to full speed , this might be the IR fuel pump/regulator problem (a pressure gauge will need to be added to verify this ) , if so save your money go with an aftermarket pump it'll last longer
Mar 25, 2014 | Ingersoll Rand Air Tools & Compressors
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
My 15 HP Ingersoll Rand Air Compressor doesn't start at times due to some load. Heard that there is some air getting caught in the Piston Head post its cut off point and hence there is too much
These pumps have unloaders to help the motor from being overloaded at startup, one type is centrifugal that is built to work off the crank, the other can be a pressure release valve that is set up to release the pressure in the chamber after it shuts down after full pump up. This is typically head as air escaping right after the compressor stops running after a complete fill.
Here is more information on the pressure release unloader.
http://www.about-air-compressors.com/unloadervalve.html
Good Luck,
Brian
Sep 05, 2012 | Ingersoll Rand Air Tools & Compressors
I have an Ingersoll Rand EP30 air compressor which has emptied its coolant out of the air inlet onto the floor. What are the probably causes and their remedy?
The unit was not turned off correctly or it shut itself down due to high temp or other problem what happens is that when the compressor is loaded (producing air) the inlet valve is open which if shutdown the pressure withing the compressor will escape through this open inlet valve which will contain oil also
Apr 29, 2012 | Ingersoll Rand Air Tools & Compressors
I got an Ingersol rand Rottary Compressor Model# PX6683U06083 Compressor it releases coolant out of the air intake I belive it was running backwards for a short while now it is rotating the right way, can...
If this type of compressor is run for any length of time in the wrong direction you will do damage for sure now if this unit is shut down while it is loaded (producing air) it will push lubricant out of the inlet filter most of the time people hit the emergency stop button to shut it done which is wrong the compressor should be unloaded first which when unloaded the inlet valve will be closed which then the compressor will be running unloaded and can now be shut down using the off button or switch not sure which one you have other reasons why this could happen failing load/unload solenoid usually the vent is plugged or bad minimum pressure check valve
Feb 27, 2012 | Ingersoll Rand Air Tools & Compressors
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
73 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
