Question about Hilti Angle Grinder: Grinder. DAG 700-P 7 In. Angle Grinder 356235
Need the electronic module after the switch - Hilti Angle Grinder: Grinder. DAG 700-P 7 In. Angle Grinder 356235
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
Where is the BCM located on a 2000 lincoln navagator?
Ford , Lincoln , Mercury in that era called a GEM generic electronic module .
The generic electronic module (GEM) constantly monitors its subsystems for concerns. If a concern is found in one of the subsystems, the GEM will record the concern in the form of a diagnostic trouble code (DTC).
The ignition switch position is very important to the GEM function. Often times, erratic or unexpected GEM function can be traced to problems with these GEM inputs.
The GEM controls the following features:
  • Wipers/washers (front/rear).
  • Warning chimes.
  • Battery saver.
  • Illuminated entry and courtesy lamps.
  • Driver power window.
  • Accessory delay.
  • 4-wheel drive.
  • Heated back lite/mirror.
Generic Electronic Module (GEM) C239
Behind center of I/P
syj~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of the module, it is necessary to upload module configuration information to scan tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Section 418-01 .
syj~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
Jul 02, 2016 | Lincoln Cars & Trucks
2003 ford ranger windshield wiper won't come on. Replaced fuse, relays, switch and motor. I'm lost. No sign of an SJB in this truck.
No smart junction box , GEM - generic electronic module ! this module energizes the relays in the battery junction box ! The gem module is behind the center of the dash !
Generic Electronic Module (GEM) Removal and Installation
  1. > CAUTION: Prior to removal of the generic electronic module (GEM), it is necessary to upload module configuration information to the diagnostic tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Section 418-01 .
    Depower the supplemental restraint system (SRS). For additional information, refer to Section 501-20B .
  1. Remove the radio chassis. For additional information, refer to Section 415-01 .
  1. Remove the center instrument panel finish panel.
    1. Remove the screws.
    • Disconnect electrical connectors.
    • Module Controlled Functions The multifunction modules consist of the following:
      • generic electronic module (GEM)
      • central security module
      • front wiper and washer
      • warning chime
      • battery saver
      • illuminated entry and interior lighting
      • driver one-touch down power window (optional)
      • battery saver relay
      • door ajar warning indicator lamp
      • safety belt warning indicator lamp
      The central security module controls the following features:
      • remote keyless entry
      • computer-operated lock system
      • trim switch unlock inhibit
      It's more then likely to have DTC'S diagnostic trouble codes stored in it's memory !
    • B1431 Wiper Brake/Run Relay Circuit Failure GEM REFER to Section 501-16 . B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM REFER to Section 501-16 . B1434 Wiper Hi/Low Speed Relay Circuit Failure GEM REFER to Section 501-16 . B1436 Wiper Hi/Low Speed Relay Circuit Short to Battery GEM REFER to Section 501-16 . B1438 Wiper Mode Select Switch Circuit Failure GEM REFER to Section 501-16 . B1441 Wiper Mode Select Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1446 Wiper Park Sense Circuit Failure GEM REFER to Section 501-16 . B1450 Wiper Wash/Delay Switch Circuit Failure GEM REFER to Section 501-16 . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1458 Wiper Washer Pump Motor Relay Circuit Failure GEM REFER to Section 501-16 . B1460 Wiper Washer Pump Motor Relay Circuit Short to Battery GEM REFER to Section 501-16 . B1462 Safety Belt Switch Circuit Failure GEM REFER to Section 413-09 . B1466 Wiper Hi/Low Speed Not Switching GEM REFER to Section 501-16 . B1473 Wiper Low Speed Circuit Motor Failure GEM REFER to Section 501-16 . B1476 Wiper High Speed Circuit Motor Failure GEM REFER to Section 501-16 Your wipers do not work at all ? did you check this fuse Central Junction Box (CJB) fuse 16 (30A)
      • The wipers are inoperative
      • Central junction box (CJB) fuse:
        • 16 (30A)
      • Circuitry.
      • GEM.
      • Multifunction switch.
      • Wiper run/park relay.
      • Wiper HI/LO relay.
      • Wiper motor.
      • GO to Pinpoint Test A .
      Before replacing parts you need to test , check for codes !
Mar 09, 2015 | Ford Cars & Trucks
What is an ECM
Electronic Control Module, the engine management computer in plain English, the brain box in slang; some car makers call theirs an ECU (Electronic Control Unit), or a PCM (Program Control Module, or Powertrain Control Module), or ECM (Electronic Control Module). May even be other names for them. The engine computer uses several sensors (as inputs) to compute fuel requirements and spark timing (ignition timing) needed for the operating conditions at that moment, then it sends signals to controllers and switches (outputs) to run the engine at optimum efficiency.
May 23, 2013 | 2002 Mini Cooper
Transfer case grinds truck only runs in 4wheel low nothing in 4wheel high or 2wheel drive
Manual or electronic t case?
Section 07-07: Transfer Case, 4x4 System, Service 1994 Bronco/Econoline/F-Series Workshop Manual
DESCRIPTION AND OPERATION Electronic Shift Operation The transfer case is equipped with a magnetic clutch, similar to an air conditioning compressor clutch, which is located inside the transfer case adjacent to the lockup collar. The clutch is used to spin up the front drive system from zero to vehicle speed in milliseconds. This spin-up allows the shift between 2-high and 4-high to be made at vehicle speeds listed in the vehicle owner's guide. The spin up engages the front lock hubs. When the transfer case rear and front output shafts reach synchronous speed, the spring-loaded lockup collar mechanically engages the mainshaft hub to the chain drive sprocket and the magnetic clutch is then deactivated. Shifts between 4-high and 4-low can only occur with the transmission safety switches closed. The vehicle's speed must also be within specified limits as determined by the transfer case speed sensor (3 mph or under). Electronic Shift Control System
This system consists of a two-switch control system, an electronic control module, an electric shift motor (7G360) with an integral shift position sensor, and a speed sensor. Switch Control System
There are two control switches located on the upper right corner of the instrument panel for fingertip shift control. The two switches are mounted horizontally and are identified as "4x4" and "LOW RANGE". Two indicator bar lamps are located in the instrument cluster.
When either of the two switches on the instrument panel control are depressed, the first thing that happens is that the electronic control module receives input from the transfer case shift position sensor to verify what position the transfer case is in (2H, 4H or 4L). Next, the electronic control module looks at the speed sensor and the park/neutral position switch or clutch pedal position switch (depending on transmission type). If all conditions are correct to allow the desired shift, the electronic control module will tell the electric shift motor to execute the shift. After the shift has been made and the electric shift motor is off, the control module again looks at the shift position sensor to make sure the proper shift has been accomplished. Finally, the dash indicator light and the pushbutton light on the control panel will be illuminated by a signal from the electronic control module indicating the desired function has been completed.
The electronic control module, located on the passenger side, controls the operation of the transfer case in response to inputs to the pushbutton control by the vehicle operator, the speed sensor, shift position sensor and the park/neutral position switch. Speed Sensor
The speed sensor, mounted on the rear of the transfer case , tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur. Shift Position Sensor
The shift position sensor, an integral part of the electric shift motor , tells the electronic control module the shift position of the transfer case . Electric Shift Motor
The electric shift motor , mounted externally at the rear of the transfer case , drives a rotary helical cam which moves the 2W-4W shift fork and 4H-4L reduction shift fork to the selected vehicle drive position.
Nov 12, 2010 | 1994 Ford F250 Supercab
Designjet 2500cp error 010036 00000100
This can be caused by a faulty electronics module, trailing cables, printhead carriage assembly, or ANY of the stepper motors.
try this...
Switch the printer off from the back, and then disconnect the trailing cables from the electronics module.
Switch the printer back on.
If the error code changes to '010037'
If the error stays as 010036, change the Electronics Module.
If it is 010037, replace the trailing cables, then the carriage assembly.
Trailing Cable Part No. C4704-60015
Electronics module Part No. C4723-60114
Apr 29, 2010 | HP DesignJet 2500cp InkJet Printer
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
Oct 10, 2009 | 2003 Ford Explorer Sport
Need to know what fuse goes where
I am not sure if this right and there should be diagram on the back of cover.
1 5A Power Mirror Switch
2 10A Daytime Running Lights (DRL),
Back-up Lamps, Transmission,
Passenger Air Bag Deactivation
Switch, Blower Motor Relay
3 7.5A Right Stop/Turn Trailer Tow
Connector
4 — Not Used
5 15A 4x4 Control Module
6 — Not Used
7 7.5A Left Stop/Turn Trailer Tow
Connector
8 — Not Used
9 7.5A Brake Pedal Position Switch
10 7.5A Speed Control Servo/Amplifier
Assembly, Generic Electronic
Module (GEM), Shift Lock
Actuator, Turn Signals
11 7.5A Instrument Cluster, 4x4, Main
Light Switch, Truck Central
Security Module (TCSM)
12 — Not Used
13 20A Brake Pedal Position Switch
14 10A or Not Used 10A: If equipped with Anti-Lock
Brake System (ABS) Control
Module
15 — Not Used
16 30A Windshield Wiper Motor, Wiper
Hi-Lo Relay, Wiper Run/Park
Relay
17 20A Cigar Lighter, Data Link
Connector (DLC)
18 — Not Used
19 25A PCM Power Diode, Ignition, PATS
20 7.5A Generic Electronic Module
(GEM), Radio
21 15A Flasher (Hazard)
22 20A Auxiliary Power Socket
23 — Not Used
24 7.5A Clutch Pedal Position (CPP)
switch, Starter Interrupt Relay
25 — Not Used
26 10A Battery Saver Relay, Auxillary
Relay Box, Restraint Central
Module (RCM), Generic Electroic
Module (GEM), Instrument
Cluster
27 — Not Used
28 7.5A Generic Electronic Module
(GEM), Radio
29 20A Radio
30 — Not Used
31 — Not Used
32 — Not Used
33 15A Headlamps, Daytime Running
Lamps (DRL) Module, Instrument
Cluster
34 — Not Used
35 15A or Not Used 15A: Horn Relay if Not Equipped
with Truck Central Security
Module
36 — Not Used
Jun 02, 2009 | 2001 Ford Ranger Regular Cab
I need a printable image of fuse block / 97 ford windstar
your owner manual sould have fuse chart. Some fuses/ekays in enine compartment. Some in car on left side of instrument panel
in car
Fuse Amps Circuits Protected 1 10 Power Mirrors, Anti-Theft Warning Light, Diagnostic Connector 2 5 Generic Electronic Module, Start Interrupt Relay Coil 3 5 Radio Illumination, Remote Radio Illumination, Electronic Instrument Cluster, Electronic Instrument Cluster PRNDL Illumination, Electronic Instrument Cluster Switch Module, Analog Cluster Illumination, Instrument Illumination 4 — Not Used 5 — Not Used 6 15 Rear Quarter Windows (LH and RH) 7 15 High Mounted Stoplamp, Brake Shift Interlock 8 25 Subwoofer, JBL Amplifier 9 10 Park and Turn Lamps, Side Marker Lamps, License Lamps, Stop Lamps 10 2 High Beam Indicator Electronic Cluster 11 15 Park Lamps 12 10 Remote Radio, Auxiliary Warning Lamp Module, Remote Keyless Entry (RKE) Module, Anti-Theft Controller Module, Radio Illumination 13 15 Radio, CD Disc Changer 14 5 Electronic Chromatic Mirror, Analog Cluster Indicator Lamps, Air Bag Module 15 — Not Used 16 15 Horns, Horn Relay Coil 17 15 Fog Lamps 18 25 Front Wiper Motor, Front Washer Pump, Wiper/Washer Relays 19 10 Generic Electronic Module (Pin 57), Electronic Instrument Cluster 20 25 Integrated Relay Control Module, Ignition Coil 21 10 Air Bag Module, Rear Window Defrost Relay, A/C Clutch, Temp Blend Door Actuator, Brake Shift Interlock 22 20 Rear Cigar Lighter, Power Plug 23 15 Multi-Function Switch 24 20 Rear Wiper Motor, Rear Washer Pump 25 10 Turn Signal Lamps, Instrument Cluster Turn Indicator 26 15 LH Aero Headlamp, Left and Right Trailer Stop/Turn/Hazard 27 15 Hazard Warning Lamps, Instrument Cluster Turn Indicator 28 15 Instrument Panel Cigar Lighter 29 15 Battery Saver Relay, Interior Lamp Control Relay, Interior Lamps, RH and LH Keyhole Lamps 30 25 Backup Lamps, Electronic Cluster 31 10 Rear Air Suspension 32 15 RH Aero Headlamp, Trailer Park Lamps 33 15 Anti-Lock Brake (ABS) Relay, Anti-Lock Brake (ABS) Module, Daytime Running Lamp (DRL) Module 34 30 One Touch Relay, LH Window Motor 35 15 Anti-Theft Controller Module 36 30 A/C Mode Switch 37 20 Door Lock Actuators, Memory Door Lock Relay 38 15 Heated Mirrors (LH and RH) 39 30 Auxiliary Blower Motor, Ref. Valve Solenoid 40 30 Window Motor (RH) 41 5 Autolamp Relay Coils, Autolamp Sensor 42 — — 43 — — 44 — —
Mar 15, 2009 | 1997 Ford Windstar
Hilti Angle Grinder: Grinder. DAG 700-P 7 In. Angle Grinder 356235 Logo
42 people viewed this question
Top Hilti Saws Experts
Tom Chichester
ray gallant
Are you a Hilti Saw Expert? Answer questions, earn points and help others
