Question about Electrolux Frigidaire Professional Series 30" 1.8 cu. ft. Microhood
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Used it last night and then was going to turn the night light on and it had no power. there is power at the plug in so was wondering if there is a reset button
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Posted on Dec 03, 2014
Model #PLMV169DCD Power stopped..source checked and is fine Is there an internal reset?
Almost all microwaves are internally fused (automotive style fuse with a ceramic case). They are only a couple of dollars at an appliance parts store get one with the same amp/volt rating which is stamped on the metal band at each end of the fuse. However, if the fuse blows repeatedly, it is a sign of a failing magnetron "tube" which cooks the food. Be sure to unplug unit before changing this fuse and avoid contact with the capacitor(s) inside. They can still hold a charge even when unit is unplugged.
Feb 16, 2011 | Frigidaire Microwave Ovens
Loss of power
yes remove outer cover its a 15 or 20 amp ceramic cartridge type fuse
Sep 21, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Jun 23, 2009 | Panasonic NN-T654SF Microwave Oven
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
The touchpad on my microwave has quit working.
possibly a stuck button which would mean a replacement pad, do the buttons bleep when you push them do some work and others dont its quite common normally its the start button or the cancel which goes(due to constant pushing) and it causes the error alternatively its a possible logic board fault which is far more expensive to replace!
Nov 12, 2008 | Microwave Ovens
Electrolux Frigidaire Professional Series 30" 1.8 cu. ft. Microhood Logo
141 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
