Question about Maylong M-270 Mobility Black Internet Tablet and Total Defense Premium Internet Security Bundle - M-270 Bundle
I have a tablet M-270 I need the screen replaced my question is how much would they charge to replace
Nothing just trying to find out how much would they charge me to replace the screen
    Sergeant:
  • 291 Answers
That depends upon the charges of a particular repair business. If they had to send for a part, they will buy the part, charge you enough that you pay for the part and whatever it cost them to have it shipped to them, and then the labour. The replacement screen is sold at Amazon for about $33 and that does not include shipping. It is there as LCD Display Screen Replacement Parts for Maylong M27 7" Tablet PC. I suspect you would find the labor fairly costly, certainly more than the cost of the part. And you would be out postage for shipping the unit to and fro. If the device cost you $200 and the total repair cost including shipping was half of that, would you have it repaired? You can google "who repairs M270 tablet PCs in the USA" or where ever your location is or check the warranty contact information (though it won't be covered) and see what they say.
Posted on Dec 04, 2014
I charge my battery of my Samsung Galaxy TAB Lite 7 SM- T116NDWAXFA White CT. I cannot use the phone for anything. If the charger is in it only shows a green 100% battery and nothing else.
Samsung Galaxy Tab 7 Troubleshooting
Tablet Doesn't Turn On No matter what you do, you can't get your tablet to turn on.
Press and Hold the Wake/Sleep Button
If this does not resolve your problem, read on!
Check If Battery Will Charge
First, connect your tablet to the power adapter. Hopefully the tablet will recognize the charger and begin to recharge the battery. If it does not, the battery may be defective and need to be replaced.
Faulty Display
If you determined that the battery was working, it is possible that the display is broken. If no light or images are visible, but the tablet has power, then the display may need to be replaced.
Bad Logic Board
If none of the previous solutions solved your problem, check all of the connections from the display to the logic board. If the device still does not turn on, the logic board in your device most likely needs to be replaced.
Screen Doesn't Respond to Touch Nothing happens when I touch my screen.
Screen protector/tablet case interferes with the touchscreen
Try removing your screen protector or case from the device, and test the touchscreen again.
Caution: Some screen protectors may not reapply properly.
Perform a Soft Reset
A soft reset restarts your device and does not erase any of your content or data. Begin by pressing and holding the Power key until your device turns off. Wait a moment, then press and hold the Power key to turn your device back on.
Bad Touch Screen
The touch screen may be bad and need replacement. The front panel (which includes the touchscreen and digitizer) should be replaced.
Bad Logic Board
If the problem persists, the logic board may need to be replaced.
Tablet Overheats Tablet is too hot to touch!
Reset the Device
Hold down the power button until the device shuts off. Let it cool down for a few minutes, then hold the power button until the device powers on.
Bad Battery
If the device continues to heat up, the battery is most likely defective and needs replacement. Purchase a replacement battery, and replace the old with the new.
Tablet Performs Slowly
Safely Remove Your SD Card
From the home screen, tap the Menu key, then tap Settings. Once in Settings, scroll to and tap Storage. In Storage, scroll to and tap Unmount SD card, then tap OK. You can now safely remove the SD card.
Close or Uninstall Applications
In the Power Usage dashboard, tap Battery Usage. Next, tap the application you want to close or uninstall.
  • To close (turn off) an application, tap Force stop.
  • To uninstall (remove from device) an application, tap App info, Uninstall, and then OK.
Verify That Your Tablet is Running the Most Recent Software
Begin by tapping the System Updates dashboard. Next, tap Device Software, then tap Check now. If an update is available, follow the prompts to install.
Tablet Doesn't Produce Sound No audio from headphones, speakers, or tablet itself.
Bad Headphones/Speakers
Check to make sure your playback method isn't the problem. Check all speaker connections and test headphones on another functioning device. If the problem is not resolved, your tablet may be the issue.
Software
First try a full restore on the tablet to make sure it is not an issue with the software.
Bad Audio Jack
If the problem is still not resolved, try replacing the audio jack. If that doesn't solve the problem, your logic board most likely needs replacement.
Aug 02, 2016 | Samsung Galaxy Cell Phones
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
Hisense Pro 7 tablet isn't working
A totally dead battery can prevent the tablet from booting. A technician is the only one that can replace batteries in tablets. Contact the manufacturer for an RMA and repair.
Apr 07, 2014 | Tablets & eReaders
Black Screen no battery picture
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Mar 20, 2014 | ASUS MeMO Pad HD 7
I have bought HANNSpad SN1AT7 Tablet ,it is full charged ,I've tried switching it on but alli get is the screen saver nothing else
Remove the battery cover and remove battery for about 30 seconds. Then replace battery and power up your tablet and see if that does not reset it.
Dec 09, 2013 | Hannspree HANNS pad SN10T1
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
Maylong M-270 Mobility Black Internet Tablet and Total Defense Premium Internet Security Bundle - M-270 Bundle Logo
Top Maylong Computers & Internet Experts
David Payne
David Payne
Are you a Maylong Computer and Internet Expert? Answer questions, earn points and help others
