Question about Olympus VG-170 Digital Compact Camera - Black 14MP, 5x Wide Optical Zoom 3 inch LCD
Camera charger not working
After plugging in the charger, the camera is not charging
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
How long do you charge fujifilm JV300 camera?
Remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power outlet. The charging is complete when the light on the charger turns from orange to green.
Jun 03, 2012 | Fujifilm FinePix JV300 Digital Camera -...
Can't find my charge adapter for my Jazz HD 188. Will it charge by plugging into the USB port of my PC?
Some phones charge the battery in the camera like a phone, but many do not. This camera has a USB connection, which is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 30, 2010 | Jazz HDV-188 Camcorder
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
Oct 29, 2010 | Cameras
Jazz DV169 issue
umm i have jazz camera and i didnt have a charger **** i bout a motorola house cahrger and it charged my camera.
Aug 01, 2008 | Jazz DV169 Camcorder
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Olympus VG-170 Digital Compact Camera - Black 14MP, 5x Wide Optical Zoom 3 inch LCD Logo
48 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
