Question about Kenmore Washing Machines
How do i tighten spin belts ?? Spin cycle sometimes will not start to spin out. Kenmore 70 series heavy duty washer.
  • Kenmore Master
  • 932 Answers
Dane, if your washer is less than about 17-18 years old, you do not have a belt that can be tightened. If it is older than that, you can get behind the washer and take the small panel off of the back, and to your left, you will see your motor hanging under the deck the tub is mounted on. On the top side of the deck there is a nut and bolt that is mounted in a slot. Loosen the nut and take a pry bar or other long handled tool and put it through the motor supports under the deck and push the motor to your left. Tighten the nut back down and check your belt. You should only be able to push it in and pull it out only about a half inch of movement. If you have a newer washer than you have a different problem and you might need to have a regular repairman take a look at it. Hope this helps!
Posted on Dec 03, 2014
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Washer will not spin
There is a safety switch on the lid ... when it went out of balance perhaps the adjustment changed or it got damaged (loose wire etc.) BE SURE TO PULL THE PLUG BEFORE ATTEMPTING ANY REPAIRS
Oct 02, 2009 | Washing Machines
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Washing Machines Logo
fordexpert
Mike Squire
Robert Rankin
