Question about Kenmore HE3 Gas Dryer
My dryer door wont stay shut while drying - Kenmore HE3 Gas Dryer
  • Kenmore Master
  • 744 Answers
Hello Debbie;
My name is Peter. I am a retired field service appliance technician.
1.) It sounds like you have a bad door latch. These are easily replaced. With a small flat head screw driver just wedge them out.
My dryer door wont stay shut while drying - 25305554-b3edjqs4ufvbcqfi2v1m52kl-1-0.jpg
Cost: $7.00
2.) You may also have a broken door switch. Push in on the white button to make sure it goes in. Check the contactor on the door to make sure it is not bent.
Cost: $24.00.
3.) Also, check your door seal to ensure it is not coming off from wear.
Part number 3390733 Cost: $41.00
Posted on Dec 03, 2014
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
Wont stay running
Was the temperature sensor or door open sensor unplugged?
Feb 17, 2014 | Kenmore 60172 Electric Commercial Dryer
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
My dryer door will not stay closed so inturn if I am not standing there watching it, my laundry will take hours to dry as I have to keep restarting
Hi you need a new latch/strike assembly on the door, if it is worn out it will not stay shut, these are fairly inexpensive.
Sean
Mar 26, 2011 | Kenmore Elite HE4 Electric Dryer
Checked fuse box, good, checked plug in, good, door shut, good, dryer won't start, was in middle of drying load, stopped. Won't start.
may be door switch, here is a website that will help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Kenmore 69101 Dryer
700 dryer wont shut off automatically
If it will not turn off on the Timed Dry cycle the failure is in the timer. The timer is the component behind the large knob on the console. If you supply me with the full model number from the front panel inside the door, I can get you a part number and approximate price of the part.
Apr 21, 2010 | Kenmore Dryers
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Whirlpool dryer no heat&wont shut off
if youre dryer is a sensor dry thats tells you when youre clothes are dry it the moisture sensor which is located below the door in the vent where the lint filter goes
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE3 Gas Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
