Question about Sewing Machines
Thread on spool keeps comin free - Sewing Machines
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
More info, please. Brand and model of your sewing machine? Can you post of picture of how you threaded your machine?
Posted on Dec 16, 2014
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
Jan 14, 2018 | PfaFF Sewing Machines
Can i use one of those BIG spools of thread to sew and, if so, how do i do it? Mary Porretta
I use serger thread sometimes on my sewing machine if I don't have the right color. If you have a spool pin that is vertical, just cut a plastic drinking straw that is tall enough for the thread spool and put it over the vertical spool pin. Sometimes I have to cut a circle out of felt or styrofoam to put under the spool so it will turn easily.
Beware though that serger thread is usually pretty linty so it will create more lint in your machine. You may not want to do this too often.
You can also put the thread spool in a coffee cup and place it behind your machine on the table. Or, if you are industrious, you can create a free-standing spool pin with something as a flat foot and a thin wood dowel. Or you can purchase a free-standing thread holder.
Jan 04, 2018 | Sewing Machines
The top thread keeps breaking
Is the thread feeding freely from the spool? Sometimes thread can get caught on something on the thread spool which causes it to snap at the needle. I suggest unthreading, and running your finger around the rim of the spool to be sure there is nothing for the thread to catch on. Then be sure to use your spool pin disks to ensure the thread is feeding well.
Mar 03, 2015 | PfaFF Creative 7570
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Thread jamming between thread spool and needle
check for burrs between the spool of thread & take up lever
May 20, 2012 | Sewing Machines
The bobbin winds really loose and uneven and then gets caught up when I'm sewing. I've checked I'm threading it correctly when winding... seems to be worse with polyester and embroidery thread. Help!
You need to keep tension on the thread spool as you wind the bobbin to avoid this from happening. Also, is there a little tension device to take the thread around between the spool and the bobbin winder? Some machines have a little silver button tensioner purely for bobbin winding to keep the thread flowing smoothly.
But I always do the following anyway just to ensure a smooth bobbin. Take the thread from your spool, through the eyelet or tensioner, then back to the bobbin and put the tail end up through a hole in the top of the bobbin. Now put the bobbin onto the winder and click it against the stop. Place the curved handle of a pair of scissors onto the top of the thread spool and apply some gentle pressure to stop the spool from bouncing and jumping while winding off. Keep doing this through the winding process.
Start the bobbin winding mechanisim, its a button on my Janome 6500, yours might be a little different. HOLD the thread tail until you've got coverage over the whole bobbin area catching the starting point. Stop, trim the thread tail off top of the bobbin with scissors, then restart winding again. Watch as the thread winds and give it a nudge with your finger tip to the top or bottom so the bobbin winds evenly across the whole spool's width.
Best analogy here is when you wind the garden hose onto the reel, if it goes on all over the place you never get the whole length on neatly, but if you wind it on neatly in an even tight coil across the spool, then back again, then repeat, you get a tidy hose. But just wind madly, it all builds up in the middle, you can't get it all onto the reel, and it won't pull out nicely next time you need it. Same thing with your SM thread.
Polyester and silky embroidery threads will be worse too as they are silky, so if the thread hasn't been wound on smoothly and under tension, then it will "collapse" with gravity, then when you use the bobbin, the thread is going to be caught on itself, will feed unevenly and be stretched, then loose, giving you less than perfect stitch tension.
My other bobbin tip is store the bobbins in a plastic bobbin tray so they are lying on their edges and under a cover. Keeps them neater and they are less likely to unwind stray threads around your sewing cabinet if you store them on the spool pins build onto the cabinet door - and it keeps the thread dust free. But I do not keep thread on bobbins for long, prefer to wind a fresh one off a new spool when I start a project and can usually complete a garment with a 3/4 filled bobbin, use the remaining few metres for handsewing, then junk the rest. Then I put the thread spool that is left back into a sealed takeway container to keep it away from UV, dust and moisture.
I hope this assists you with your machine and certainly if this doesn't resolve the bobbin issues, then I'd suggest you visit your dealer and ask them to demonstrate the technique on your machine to see if there is a technical issue with it.
Apr 10, 2011 | Elna Xplore 8600 Computerized Sewing...
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
Needle keeps breaking when embroidery unit is attached
Make sure the top thread is not catching and causing the breakage.
Sometimes the thread unwinds too fast and catches on the spool pin and sometimes there is a rough spot on the thread spool that catches the thread.
Thread nets will help eliminate the fast unwind (pooling) - you can find them at sewing machine dealers.
If the thread spool has a rough notch that is catching the thread, smooth it with an emery board or turn the spool so the thread feeds from the opposite end.
Mar 17, 2010 | Singer CE-100 Futura Computerized Sewing...
Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Feb 24, 2010 | Brother Sewing Machines
I have a Simplicity Embrodery Machine, and the needle keeps breaking. I have checked the bobbin, changed the bobbin, changed the thread, changed the pattern. It sews for about 5 seconds and then breaks.
It could be the thread is hanging up and breaking the needle.
Check the thread spool for nicks - turn the spool so the thread is feeding from the bottom of the spool.
Watch the thread as the machine stitches, if the thread is pooling at the base of the spool, use a thread net on the spool.
Open the needle plate and remove the bobbin and bobbin case - clean out any lint or thread snips that may have accumulated there - do this often to help the machine work as it should.
Feb 19, 2010 | Simplicity Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
