MY WASHING MACHINE IS BLOCKED. HOW DO I UNBLOCK IT
IT STARTED MAKING A TERRIBLE NOICE. I THINK IT IS BLOCKED
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
WHAT DO U MEAN?
Posted on Dec 05, 2014
aborcass
  • 2651 Answers
SOURCE: Dancing washing machine
if its real new as in you just installed it look behind hte unit for shipping braces that haven been removed.. they keep the machine solid in shipping and reek havok if not uninstalled
Posted on Mar 18, 2008
dutchman05
  • 487 Answers
SOURCE: washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
Posted on May 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: REMOVAL OF BLOCKED PUMP ON WASHING MACHINE
Remove the lower portion of the front panel. 3 screws.
Twist the pump filter and pull to remove it.
Posted on Mar 17, 2009
  • 1382 Answers
SOURCE: I have a hmwm 6000 washing machine and i suspect
Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
Posted on Aug 30, 2009
SOURCE: Bosch WAA28160GB front loader blocked
leaking from bottom centre of door when closed
Posted on Oct 11, 2009
My Kenmore 3.6 cu. ft. High-Efficiency Top-Load Washer is making a very loud thumping noice what can it be and how can i fix it
The flexible joint under the tub needs to be replaced. This will require disassembly of the cabinet to access the joint
Jan 17, 2013 | Kenmore 24032\24036 Top Load Washer
My facebook site is blocked.how can i unblock it.
sorry to hear that, unfortunately, you cant unblock it. or its possible that its just a browser issue, or if its caused by a virus, making you think it is indeed blocked. one way to verify is if the reason why its blocked when you used a wrong password or username several times, things like that. but if you think theres no reason for facebook to block you, try using firefox or googlechrome. or try loggin in using another pc.
Apr 06, 2011 | Facebook Social Network
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin making noice
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Washing Machines
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Err20 No drainage
remove the hose from the outlet and lay it as flat as poss into a bowl. fill the machine up and see how much water starts to run out. if there is a lot then there may be a blocked outlet instead. the way to attempt to clear a waste hose out without removing it is to buy a flexi unblocker (like a bendywound wire) from a handyman shop and ram it up the hose. tone.
Jun 09, 2007 | Zanussi FJD1466S Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
