Question about Tally Office Equipment & Supplies
How do you fix error code fault platen cal 190 on tally 6306
After replacing platen sensor to correct, I run the print gap detection, it flashes "Correction", and the last # it displays, is between 191 and 214, book says its supposed to be around 50
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
Just clear nvram first. then in operator menu go to print gap then mode select manual then enter.
now press clear key adjust print gap by pressing + & - key together when it show 190 then decrease it to 50 and save value.
Posted on Jan 10, 2015
SOURCE: blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Posted on Aug 26, 2007
iservice
  • 318 Answers
SOURCE: L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Posted on Oct 31, 2008
leroyal
  • 2120 Answers
SOURCE: I cant find out how to turn off error correction mode
Turning off ECM / lowering baud rate, neither will matter. Fax machines are ANALOG devices. MagicJack, Vonage, DSL are DIGITAL phone lines.
Your fax machine will not wot work reliably.
Posted on Jan 28, 2009
SOURCE: paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
  • 117 Answers
SOURCE: My printer shows an error of platen cal cable.How
Hi
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Hope it can resolved issue Thanks you for using Fixya
Posted on Mar 22, 2010
Error message PAPER OUT and PLATEN CAL required Tally 6218. Please help me. Esli mojno po ****** otvet daite. subat@mail.ru
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Oct 11, 2011 | Tally T6218 Matrix Printer
Tally 6306 Matrix Printer hamer voltage 1 Error
Hammer voltage 1 is generally the logic board. One of the driver fets have gone bad. If you have schematics for the board you can fix otherwise a new board is required. Moving the temp cal is a bad idea. can cause a fire real easy.
Oct 01, 2011 | Tally 6306 Matrix Printer
Hi my Tally printer giving an error Pw Sensor defekt plz advice me
You are seeing the "PW Sensor Defect Error" because the printer is detecting a fault with the Paper Width Sensor.
The Paper Width Sensor is located on the print head carriage and detects the paper edge to prevent printing on the platen.
You can check the follwoing;
  • Ensure the print head cable is not damaged and makes good contact with the printer and print head carriage
  • Ensure the Paper Width Sensor is connected correctly to the print head carriage assembly
  • It may be necessary to replace the Paper Width Sensor
Mar 09, 2011 | TallyGenicom 2280 Matrix Printer
PRINTER SHOWN PLATEN CAL CABLE IN T6306
if your platen calibration is not done.
1 Resat All Platen Connection of cabal
2 Replace Logic Card
3 Check Platen Moving proper
4 Than Check Sensor And Platen Aliment
5 Than replace Platen Sensor
6 Please Check Platen Motor
Regards
yogendra Sharma
Nov 27, 2010 | Tally 6312 Matrix Printer
Tally genicom 6306 paper out error message let me do what? Please help! thank you in advance.
This sensor can be re-calibrated.
Press LF and Enter for 5 seconds to enter Tech access mode.
Press menu scroll to test then press enter.
Scroll to Diag and press enter.
Scroll to cal-paper and press enter.
Scroll to paper out calibration and follow onscreen prompts.
If it still fails replace the sensor.
MRP provides IT Parts Product Supplies and Services
Jul 28, 2010 | TallyGenicom 6306 Matrix Printer
I have a line matrix printer lipi 6306L. When I switch on the printer it shows a fault : Platen Cal Cable How to solve it
Jan 25, 2010 | Tally 6312 Matrix Printer
Platten cal cable
do platen calibration then also same problem change platen sensor
Dec 12, 2008 | Tally 6312 Matrix Printer
Platen open error message on tally t6218 line printer
there are two reason behind the problem . 1 .the problem may come from the logic board.
2.and the platen sensor. change the platen sensor. if not solved change the board.
Sep 16, 2008 | Tally T6218 Matrix Printer
Tally printer 6218
May be platen gap is high check the platen gap. If the platen gap is not proper adjust it manualy.
Aug 21, 2008 | Tally T6218 Matrix Printer
224 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
