Parts and price K-2246B and 50P-304-A and 50P3011-A
DOES 50P MEAN SOMETHING ?
Not knowing what brand it is I think the 50P is a model number. Has nothing to do with power or charging capacity.
Mar 17, 2015 | Health & Beauty
Tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
on Jul 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I have bought a second hand Citizen Ladies Gold Tone EW7012-50P watch and need a operating manual.
You will get it from here http://www.princetonwatches.com/shop/EW7012-50P.asp
May 07, 2011 | Watches
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
How do we covert our panasonic TH- 42PWD7B to HD?
Replace it if you want true HD. The TV has 640 × 480 pixels (dots) in use for 16:9 or 852 × 480 dots for 4:3. This translates to 480p or SD resolution.
You can watch an HD signal with downconversion. You will also need a digital to analog converter for OTA signals since the TV doesn't have a digital tuner (ATSC in the US) It reads NTSC, PAL, PAL60, SECAM, Modified NTSC signals in the following formats: 525 (480) / 60i · 60p, 625 (575) / 50i · 50p, 750 (720) / 60p · 50p, 1125 (1080) / 60i · 50i · 24p ·25p · 30p · 24sF ···· SMPTE274M, 1250 (1080) / 50i.
I hope this helps.
Jan 11, 2011 | Panasonic Televison & Video
Nsm 2000 jukebox
You need a service manual. Thats a must if you own any jukebox. You may be able to find one in print or cd on ebay. Shop around, they vary in price and you can find one reasonable if you try.
Dec 23, 2008 | Juniper Networks IDP Upgrade Kit for ISG...
Kenwood kvt 717 dvd
I think this may be it, here: http://www.partstore.com/Part/Kenwood/Kenwood/KVT717DVD/Kenwood/Kenwood/J84015005/New.aspx If not, do a search for your model number on the same site. They have over 100 replacement parts for that model.
Jul 13, 2007 | Kenwood KVT-717DVD Car DVD Player
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
