Question about Philips Audio Players & Recorders
My Philips hts3530 dvd home theatre system is working for a short period then the sound turns off and a huge beeping noise is coming from the speakers
  • 54 Answers
Check speaker wires make sure neg and pos are not touching anywere
Posted on Dec 03, 2014
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
I have got Philips Home Theatre 5.1 (DSP 25000) , but it is not giving expected sound. Right Rear speaker and Left Fornt Speaker are not giving any sound . Please let me know the solution. I have connected...
Firstly make sure you have connected the speakers to the main system in an proper order. Certain system's have the name of the speaker's mentioned at every output line which is at the rear of the system. If you would connect the wrong wires then it eventually would not play the sound. once this is done make sure that the wires of each speakers are split into two at both the ends. They are normally coded in red and black colours at the tip of the wire. Check if the red of the wire is connected to the red of the system and so on for all the speakers. So try removing all your connections and do it all over in a proper way.
Sep 12, 2010 | Philips HTS3450 System
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
PHILIPS HTS3450 DVD HOME THEATRE SYSTEM NO SOUND
quiero saber como puedo ecualizar el sonido con el control manualmente
Aug 11, 2008 | Audio Players & Recorders
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
127 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
