Question about Saeco Aroma Espresso Machine
I can make a good expresso but no steam comes out the steamer...
- I opened the top: no corrosion - Tried to to prime it. - Fixed myself an espresso, drank it to get +3 of energy and rolled a 7 on a 10-face dice to get +2 of success. - Cried - Went away for work - Wrote on this wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Put a paper clip in the wand and that should do it
Posted on Dec 11, 2014
espressodoc
  • 29 Answers
SOURCE: red warning light does not go off
The red warning light is multifunctional. Be sure all your components are in tightly especially the central brew unit.
Posted on Jul 29, 2007
mirran
  • 515 Answers
SOURCE: I have a Saeco Incanto
Do you have a filter in your water tank?
if you have a filter, remove it and try.
Posted on Jul 10, 2008
SOURCE: Can't prime Starbucks Estro Vapore espresso machine
I can't get that screw off that holds the screen down. I'm trying to change the rubber gasket. The screw just goes round and round in both directions! I'm afraid to just pry it off!
Posted on Jul 18, 2008
EsWorld
  • 1618 Answers
SOURCE: The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Posted on Mar 25, 2009
SOURCE: Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Posted on Nov 29, 2009
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
My expresso machine won't steam. Just suddenly stopped. Have tried running vinegar through system, but still won't run through steamer.
Hi, I dont know which brand machine you have, but I should be able to work out what is wrong. If your machine has a press button or turn knob steam tap, then it could be the solenoid which opens the steam flow. The solenoid itself maybe stuck or the coil maybe faulty. You just need to work back from the steam arm to work out which solenoid it is. It should make a clicking sound when activated. Commercial machine solenoids canbe disassembled and cleaned. If its a domestic machine, then just replace the solenoid. Also, some machines have a micro switch that activates the steam valve. If its faulty, then replace it.
If its a domestic machine you have, then another thing that maybe at fault, and that is the thermoblock (small boiler). If it doesn't heat up then no steam canbe made. The thermoblock has an element inside, and they can not be replaced. You have to replace the whole thermoblock. It can be easily checked with a multi meter to see if the circuit is broken. On some thermoblocks, is a thermostat or overload sensor. It is also easily checked with a meter.
So lets break it down a) solenid
b) micro switch
c) Thermoblock
d) thermostat/ thermol overload
Hope this has help you. Id be looking towards the thermoblock. Dazza
Oct 20, 2011 | Krups Gusto 880-42 Espresso Machine
My milk steamer is no longer steaming. Some steam comes out but not enough to steam the milk. The expresso part is working fine as I recently used a Krups descaling kit on it.
From your message that it is clear that the steam is coming but it is not sufficient to heat the milk, so kindly call the customer care to sort the problem as you can't do it
Thank you.
May 08, 2010 | Krups XP4030 Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Barista Coffee Expresso machine
yea, that happens to me. Try this way....Turn on the Barista, wait til the the steam's green light, then push the steamer button on, wait for a good 1 minute. It should be blowing hot air by then. Good Luck
Aug 22, 2007 | Starbucks Barista Utopia
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Coffee Makers & Espresso Machines Logo
105 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
