Question about Canon MG6150 Printer
Ive got an almost continious repeating error 5200 on my MG6150
The printerhead is already washed cleaned cartriges are all full the chips haven been reset the powercable out and waiting a long time does not help how can you reset the printer ?
  • Henk Tinga
    Henk Tinga Dec 05, 2014
    After the printer had been at rest for almost 24 hrs it
myob247
  • 1342 Answers
SOURCE: error 5200
Solution
Posted on May 12, 2008
  • 739 Answers
SOURCE: Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Posted on Dec 22, 2009
muntejaya
  • 10421 Answers
SOURCE: Getting error code U052 (
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay lnkv
Posted on Feb 12, 2011
  • 2246 Answers
SOURCE: always time sow Error number; 5200 A printer
Here's How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Posted on Mar 16, 2011
SOURCE: error 5200 of canon pixma
You can try the solution I found here:
http://error-in-printer.blogspot.com/2012/12/canon-pixma-mx328-printer-error-5200.html
The solution is about the proper reset procedure to fix error code 5200 on canon pixma mx328 printer.
Good Luck!
Posted on Dec 11, 2012
No ink on print out from canon mg6150, please help
how much ink is in the ink Cartridges?
have you changed the ink cartridge recently ?
You may need to clean the print head.
see http://www.cityinkexpress.co.uk/cheap-printer-cartridges/canon/pixma-mg6150/mg-series/cleaner/printhead-cleaning-cartridge/yellow
http://www.ebay.com.au/itm/Printhead-Ink-CLEANING-KIT-Fix-Canon-PIXMA-MP990-MG6150-MG6250-QY6-0078-000-New-/250992770857
seems to look like it may be a manual procedure with the mg6150 rather than a computer setting in the printer properties. Look under properties to see if there is a computer generated head clean .
Feb 24, 2015 | Canon Office Equipment & Supplies
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
Hi
Dec 22, 2009 | Canon Office Equipment & Supplies
Print Qued--No Print--Cartridge Error Problem--?Prinerheads?
It sounds like you need a new printhead, with that error the printhead is defective. The printhead is BC21E around $40.00
Jun 25, 2009 | Canon BJC 2100 InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Toner showing empty
first, if you refilled your toner, the printer will always tell you, that you are not using original toner and red light will blink. second, if printer tell you every time to replace different color, then you need to clean a chip reader and chips on toners. take out all toners and pc drum. under toner rack there is a chip reader, clean it with pressure air and reinstall
Jun 03, 2008 | Konica Minolta magicolor 2400 Laser...
Black ink problem
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Apr 13, 2008 | Epson Stylus R265 InkJet Photo Printer
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MG6150 Printer Logo
old marine
old marine
