Why is it when I light my heater the flame goes out and theres no fire there is a full tank of fuel any surgestions on this please
Nothing yet thinking does it want a knew wick
  • 2,024 Answers
Not sure what kind of heater but if it heats with fuel oil your wick is either burnt so it's too short or you have it set too low. I had one a few years ago and had to replace the wick.
Posted on Dec 06, 2014
Buffalo12980
  • 625 Answers
SOURCE: Dyna Glo 95-c flame height
check your air passages for a blockage. the wick just aids in burning your fire.
Posted on Nov 04, 2007
  • 4 Answers
SOURCE: Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Posted on Nov 02, 2008
cinderella_3
  • 4 Answers
SOURCE: Flame goes out Monessen Ventless fire place Model DLX24.
take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Posted on Jan 17, 2009
carldc3
  • 82 Answers
SOURCE: Toyo Laser 73, starts, fires then goes out, flashes EE02
here is the problems associated with code EE02.
problem cause solution
no ignition: out of fuel check fuel gauge or tank, refuel
fuel tank valve closed open valve turning clockwise
air pocket in fuel line push reset button on the fuel sump, located right inside .
once
clogged flue pipe clean flue pipe
clogged fuel strainer clean fuel strainer
ignitor,circuit board, consult dealer
flame sensor, or fuel
pump malfunction.
it sounds like it may be a clogged strainer located in fuel sump or a bad circuit board hope this helps
Posted on Jan 23, 2009
  • 2976 Answers
SOURCE: tank-top propane unit won't stay lit
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Posted on Feb 24, 2009
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
Unit fires and flame seems to skip seems to go out for a half second then pops and burns again untill next skip. flam continus to burn and will heat popping is anoning. when first lights will smoke and...
Sounds like there might be some water in the fuel?
Take a strong flashlight, and shine it into the tank-- does it look dirty?-- can you see water on the bottom? Try draining and cleaning the tank, and make sure the suction filter is clean-- and in tact.
And yo are using kerosene-- not diesel fuel, right?
Mack B
Jan 19, 2011 | Reddy R115DT Oil Filled Utility Heater
I have mpi monitor e 13 keeps coming up
E13 means that the flame rod couldn't detect fire during it's 300 second cycle. If you can see fire through the window, start by cleaning the flame rod.
If no fire is visable after 300 seconds, feel the ignitor cover. If it is warm, check the fuel system, chances are the ignitor is working. If it's cold you have a bad ignitor.
Dec 26, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
Burner fires but goes out after a few minutes.
Are you 100% sure there is water in it, try opening the pressure relief valve slightly to verify tank is full. If it is full check that by-pass valves at rear of tank are in normal operation position. When you say won't run very long, how long would that be approx.?
Jul 30, 2010 | RTO Atwood Water Heater - 6 Gal LP
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Runs a few minutes and quits
hi this could be 3 problems ? no spark so vapour not igniting so excess vapour coming out as smoke, if it ignites stays on for a while goes out the flame probe is faulty, fuel filter is blocked needs new one , the fuel pipe going into tank has a non return vavle in it ( its a plastic ball in line with pipe ) if this is missing or stuck it allows fuel to drain back into tank and causes a air lock in heater causing vapour into chamber result in smoke coming out of end, as a quick fix for that you can fill pipe with fuel bend it so its traps in fuel like fire place pipe in tank when stopping fire stick mole gripps on pipe so next time fuel is there ready
Jan 22, 2009 | Reddy Heater 60,000 BTU Kerosene...
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
