Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik built in dishwasher
The problem we are having is tht he dishwasher does not clean properly, either the top arm rotates or the bottom arm rotates but never together
  • 142 Answers
These arms spin based on water pressure generated from the washer itself.
Run the washer. As soon as the washer is full of water and the wash cycle starts, open the door and verify that you have at least a couple inches of water in the machine. If there is not enough water in the machine, the pump will not be able to provide pressure. If this is the case, the filling sensor is malfunctioning and will need to be checked.
There's a pump that provides water pressure. It's at the bottom of the machine beneath the lower rotating arm, probably beneath additional plastics. Remove these two items and verify that there is no debris blocking water from reaching the pump as if this is the case, water pressure cannot be generated.
Good luck... let me know what happens, and please rate accordingly.
Posted on May 09, 2008
My dishwasher does not clean all of the equipment within, i have noticed that the top and bottom water rotary spray arms do not spin when machine is on.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Mar 01, 2011 | Tecnik Dishwashers
Dishes not cleaning
There is dirt floating around in there that you cannot see...replace it and you will be washing again...
That problem can have many and varied solutions...I have tried to put together in this tip the most common and easiest to checkout problems. For many of the spray arm problems the solution will be here, but it would be impossible to cover every possible problem in any answer with out actually being able to hands-on disgnose the problem....
Dishwasher2_bing.gif Spray Arms not Spinning
May 30, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Mar 08, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bottom spray arm not rotating
The arm usually will stop rotateing because there is a obstuction in the arm itself you will need to remove the arm normally unclips (older machine used to scew off)When you have the arm out check all hole top and bottom and open any that are blocked rinse out arm and replace give it a wash and see if there is any improovement,let me know.
Feb 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
No water from top and bottom arm
I'm not familiar with that exact unit. However, all dishwashers use a solenoid valve and pump to either send the water to the drain or to the arms. If the water drains, the pump is good. Check the solenoid valve. It may be jammed (toothpicks and food particles are wonderful) or burned out. If the valve is good and working, your timer is a suspect.
Jun 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
380 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
