How to resolve error100 of canonIR1610 copier
  • 128 Answers
Try replacing the Drum unit or check for a broken tab on the drum assembly where it fits into the laser shutter. The code indicates a bad laser but usually on this model the shutter is not being opened/actuated .
Posted on Dec 03, 2014
Dear sir,I have e studio 207 copier it has call for service I want to resolve this immediately pls tell me soon sir,
Hello Sashikala:
Please contact the service department of the store that you bought this copier from. I am certain that they will assist you in resolving the problem.
Oct 24, 2015 | Toshiba e-Studio 207 Copier
How do i fix Error100?
Assuming this is a Canon Copier based on the error code you referenced--Bad laser assembly needs to be replaced or , if you are lucky, the laser shutter is not being actuated and you just need to find out why the shutter is not being opened. Probably just a broken plastic tab. Please post the Brand name and model # of the equipment in the future to get the most complete answer possible.
Dec 03, 2014 | Office Equipment & Supplies
How to resolve error100 of canon1r1610 copier
uninstall the driver and then install it one more time
Canonpc d340system error100
the machince is giving an error of e100, i have tried to change the drun together with rear unit but still gives the same error
Dec 21, 2013 | Canon PC-D340 All-In-One Laser Printer
Error E0
Error E0 results from the copier being turned off and on immediately after an error. Most likely there is another underlying error on your copier that needs to be resolved, but in some cases leaving the copier powered off for a couple hours can resolve the problem automatically. If you see another error code (most likely E000, E001, E002, or E003), your copier may need repairs.
May 10, 2012 | Office Equipment & Supplies
PRINTING A SHADOW
Replace the upper heat roller first, 99%, this will resolve your problem, after replacing the heat roller if the problem is not getting resolved you have to replace drum, developer cleaning blade and maincharger together because all are consumables and replacing it together will give you a betttter life span . Rate this after your problem get resolved
May 04, 2011 | Sharp AR-M205 Copier
What is the code for the service mode for Imagerunner 2010f I hqve tried *28* to no avail the problem I hqve is after changing out the drum roller I am geting an error100 code. help if you can
Hey!Service mode wont help!!On the drum unit there should be a pin on the left hand side of the unit that opens the shutter in the laser!If u can the best would be to strip out the laser and remove the cover over it and remove the shutter or get a new drum unit!!Good Luck!!
Dec 07, 2010 | Canon imageRUNNER 2010F All-In-One Printer
Canon fax l100 .........problem error100.........help me and thanks
This error means the receiver cannot receive the file properly due to poor line signal or conditions. If there's a feature that you can adjust the transmission level, try to boost it. You also need to set the speed 4800 bits per second. There are many solutions, but they can only be implemented by the technicians. This error also signifies that the receiver's machine isn't receiving the file/data because of low transmission level. If you can set the echo counter-measures, that'd be very helpful. Also try to dial the receiver's number slowly, sometimes this helps. I am sorry that I can't provide you more than these information since you'll not understand even if i do. If you insists, i'll do it for you. Good luck. Thanks for using FixYa.
Jun 06, 2010 | Office Equipment & Supplies
Copier won't print. Scan bar is stuck and does
Issue has been resolved from BT ,hence resolving the ticket.
Nov 19, 2009 | Office Equipment & Supplies
Problem error 100
E100 is a laser scanner error, you blow dust into the laser unit.
Aug 04, 2008 | Office Equipment & Supplies
jasbo
jasbo
