Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
I am not able to remove the drip tray from the machine, it' feels like it's catching on something. Also the warning light ( one between the empty water light and the descale light) is on permanently
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Even after descaling?
Posted on Dec 11, 2014
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Samsung Dishwasher error light "heavy" or leakage error
I had the same problem, SAMSUNG did not want to tell me how to fix so I jumped in with research I found that after you remove the power supply, i.e. plug, 1) you need to remove the dishwasher and turn it upside down. 2) There is a white sensor tray; 12x12 approx. on the bottom held in with two screws, remove the screws and use a flat head screwdrider to undo the clips holding the tray in place. 3) Dry the tray and sensor tips with a towel and replace the tray. Bammmm, you have just fixed the LE(leaking error) code error.
Feb 19, 2013 | Samsung DMT400RHW Builtin Dishwasher
I have a AEG OKO Favorite 675 dish washer and if you start it or open the door it sounds as if it is just draining all the time, what can be wrong?
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve.
To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit.
I gained the above knowledge by bitter experience.
Dec 27, 2012 | Washing Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
My new lg direct drive front load drips bleach down the front from the detergent drawer. The machine is level. Sometimes will puddle on the floor. Any suggestions?
I suspect that it is the conditioner/softener tray which is causing water to overflow from the dispenser drawer so it needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 30, 2011 | Washing Machines
Miele 4070 watersystem fault but the catch tray has no water so it's not overflowing. What might this be?
it is leaking internally. When the drip tray is full, it tells you to empty the drip tray. when the machine has a problem and develops a leak, it locks up and displays watersystem fault. contact miele at 800 843 7231 and they can put you in contact with a service center in your area.
May 25, 2011 | Miele CVA4070 Coffee Maker
I have the Vienna Superautomatica. It turns on, the green "on" light ilights the red light blinks on and off. The grind button has no effect. Nothing is clogging the grinder - sometimes there...
Hi
Blinki9ng red light usually something is not in place. The water tank empty. grinder empty or cloged, the brew unit not seated, dredge drawer not in place, or the usual cluprit is the drip tray. There can be something behind the drip tray that is keeping it from seating ( it has to lock into the 2 holes in the bottom of the base) Try to push the drip tray in and down and see if it will work.
May 16, 2011 | Saeco Vienna SuperAutomatica Coffee...
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
Saeco Easy automatic espresso machine
Heating element is probably burned out and needs replacing.
Aug 28, 2017 | Saeco Easy Machine super automatic...
Coffee Makers & Espresso Machines Logo
64 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
