Question about Blade Saws
Is there a steel cutting blade for genesis band saw model # GBS900
Look @ question
    Sergeant:
  • 468 Answers
I got my band saw blades on sawblade.com. They customized blades and they offer different types of metal cutting blades.
Posted on Jan 02, 2015
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
Editor925
  • 285 Answers
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Posted on Apr 18, 2009
  • 67 Answers
SOURCE: Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Posted on Jul 24, 2009
How long is replacment blades
Blade length is 93" or 7'9" . I get my blades from sawblade.com , I use bi metal 10-14 blade for cutting steels.
Jul 08, 2014 | RTO 7 X 12 1HP Turn Pro Band Saw
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Amada HA-250 horizontal band saw troubleshooting guide.
You can download free Amada manual on bandsawmanuals.com .
May 30, 2014 | Saws
Vanguard vn30
That I doubt. Why don't you try checking sawblade.com . I knew some guys who are into aircraft get blades from them . They have good band saw blades.
May 19, 2013 | Saws
How do you line the blade on a shopfox m1014 it wont cut stright
You should check your manual for correct blade tracking adjustment. Place the guides properly. You should use a fine
blade as well. I have 7x12 band saw and I am using Haltbar band saw blade on it. I got it on sawblade.com . The blades
are really good.
Mar 27, 2013 | Shop Fox Metal Cutting Band Saw 7in. x...
How to change the blade
You may want to check this blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ .
I hope this can help you.
Jan 11, 2013 | Genesis GBS900 9-Inch Band Saw
I'm looking for a table top band saw that will cut 4140 and harder steel, what kind of blade and saw would you recommend. ?
i have a great company for you to contact to find the perfect blade for your needs. go to www.doall.com and click on the doall sawing tab and find the customer support phone number. call them during business hours and you can get at blade tech on the phone that will ask you a few questions to what saw you have and what your cutting and they can put you on the perfect blade. i use them for a bandsaw we use at work, we manufacture awnings and signs. i get all my bandsaw blades from Doall
Dec 24, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
Jan 10, 2010 | Proxxon 28174 24-Tpi Fine Toothed Band Saw...
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Saws Logo
74 people viewed this question
Top Blade Saws Experts
80stech
Are you a Blade Saw Expert? Answer questions, earn points and help others
