Question about Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR
How to re boot hannspee tablet
Tablet will not open up .allowed the tablet to run out of power. Recharged tried to start the tablet. THE tablet just Keeps cycling on and on .model SN1AT71B
  • 26 Answers
Have you tried factory reset? Press volume up key and the power button at the same time.
Posted on Jan 15, 2015
My tablet keeps cutting off. I turn it back on only to have it cut off again. It is fully charged.I HAVE NO IDEA WHAT TO LOOK FOR CAN ANYONE HELP ME
From what you are saying, I think it is one of two problems; the battery or an operating system error.
If it is the first, then the battery is no longer holding a charge. If you have to keep it plugged in to keep it running then, and the tablet immediately turns off when it is unplugged, your battery is worn out. There really is no fix for this. it is time for a new tablet. Typically lithium batteries only last 3-5 years, but it really depends upon the make and model of your tablet as to how long it could last. In tablets, "you get what you pay for" really is true. I've seen some types of tablets have batteries only last 6 months depending on the brand and the way it is used. Cheaper tablets aren't made for games and will burn out pretty fast with constant use.
2. If it keeps rebooting even when it is connected to a power source, then it is a operating system error. Again, knowing the make and model of your tablet would help to troubleshoot the problem. If it is continually rebooting on it's own, then you need to find out who the manufacturer is, what the model number is and there is a specific sequence of buttons you need to push to get into the boot-loader (assuming it is an Android) and either boot the tablet into safe mode, or select factory data reset.
Safe Mode will allow you to run the tablet's basic functions so that you can delete something that may be causing the problem. Sometimes an update or an app you recently downloaded can cause a boot error. In that case you would uninstall either the update or the application you think is causing the problem then reboot the tablet.
Selecting factory data reset will wipe out everything of your personal data on the tablet including all accounts, apps, documents, and pictures. This restores the operating system and settings to what they were when the tablet was brand new.
Hope that helps.
May 25, 2017 | Tablets & eReaders
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
How to reset a freezed tablet ZTE v72
If the tablet is unplugged and the rechargeable battery either removed or allowed to run out of power the device will power off. After reconnecting battery / power and booting up the next time recommend to do all updates to hopefully make the operating system stable and prevent freezing up.
Jul 23, 2016 | Tablets & eReaders
Keeps rebooting
there are many reasons, why this happens, try this instead, if this will help. boot to recovery, depending on your tablet, for android, turn off your tablet, then while turned off, press volume up and power same time till you see your tablets logo, wait until it opens recovery, then select wipe data/factory reset. this will bring back the tablet to its original state or factory default settings, after a wipe, select reboot system, the tablet will turn on again, loading the settings like the first time you bought it, and see if that helps.
Sep 24, 2015 | Samsung Galaxy Tab Tablet PC
Will not boot-up or start
Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
If it won't power on at all, try out these instead:
What to Do When Your Android Phone or Tablet Wont Turn On
My Android Tablet Wont turn on Anymore And cant take the back off
If those do not help, then contact the manufacturer.
I post on behalf of HP.
Jul 29, 2015 | Tablets & eReaders
Nobis tablet stuck on go
try holding power button in for like 30 seconds to completely down power tablet
Jan 02, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
How do i open the proscan 8 in tablet ?
When you press and hold in the power button it should boot up. If it doesn't the battery might be dead so charge it up and try again. If it doesn't boot up after charging we need more information.
Are you getting any kind of a screen or just nothing?
Oct 23, 2014 | Proscan 8 4GB Android 4.1 Tablet
Why won't my tablet turn on?
are you sure that you have recharged the battery fully ?? It could be some kinds of virus, try to remove all connections and extra cards and try to open it again
Jun 09, 2014 | Hannspree 10.1-INCH QUAD CORE TABLET PC T7...
My proscan tablet won't power up
The tablet may be dead and need recharged. OR so low that it turns itself off. My 10.1" tablet has a reset button on the back that I have had to use once before.
Feb 08, 2014 | Android 7 inch Tablet
Tablet was recharged and now though it opens, it is not accessing the access page (password). What to do?
hi,
press and hold the Power button until it completely goes off and then power it back on and see if that helps
thanks
Oct 19, 2013 | Acer 64GB 8.1" Iconia W3 Tablet
Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR Logo
207 people viewed this question
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
yobo007
yobo007
ka4iup
ka4iup
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
