Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
How do I know which wires go where on a lasko tower fan, I'm trying to use the lasko motor on a blower
To use my lasko 2033117R motor in a blower, how do I use the gray,black,white,yellow,red and blue wires ?
    Sergeant:
  • 242 Answers
You have to cut the blue wire, WAIT NO, the red wire. No the blue wire, yes cut the blue wire. Phew that was close. (How the hell is anyone going to know the answer this question? you took the think apart so you can see what the wires are for)
Posted on Dec 03, 2014
My grandchildren pulled the power cord out of my Lasko 2510 tower fan. I have NOT cut any wires, just opened the casing. Where do the wires connect?
If there is a condenser at the motor, the power lead may be attached to it and the neutral to the common.
Jul 01, 2015 | Lasko Dryers
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Redoing butchered wiring on a 2000 honda civic
Assuming you need to find out your wire combination for your radio, here you are: Constant 12V+ Blue/White Switched 12V+Yellow/Red Ground Black Illumination Red/Black Left Front (+)Blue Left Front (-)Gray/Black Right Front (+)Red/Green Right Front (-)Brown/Black Left Rear (+)Blue/Yellow Left Rear (-)Gray/White Right Rear (+)Red/Yellow Right Rear (-)Brown/White
May 31, 2011 | JVC Car Audio & Video
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
What color are the wires on a 1992 eagle talon to hook up my new stereo.for example.what color is the speaker wires,left front r front left rear right rear.thank you
Here you go.
1990-92 Eagle Talon Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Left Rear Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6 1/2" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
Jan 16, 2011 | 1992 Eagle Talon
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
Fan comes on but will not blow cold air
This fan has a blower motor which will eventually fail.
The fan will still oscillate , but the blower motor will burn out. The motor thermal fuse will fail , lower bearing failure and armature burn out. No replacement motor less than fan price so, when it goes buy a better longer lasting fan.
Sep 30, 2010 | Lasko 2515 Tower Fan
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
340 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
