Question about 1976 76 Chevrolet Monte Carlo Light Bulb-1976 Chevrolet
How to replace 1976 oil seal on a 305 chevy monte carlo
    Sergeant:
  • 242 Answers
Need to know which oil seal...If it is a Rear Main Oil Seal you will have to remove Trans or Engine...It is easier to remove Trans...However If it is either front or rear main engine seals it would be a good idea to just remove engine and replace Both front and rear seals of engine ..,Also oil pan gasket b cause of vehicle age and or mileage...BUT I need to know which seal and I can guide you through the procedure of replacement...
Posted on Dec 03, 2014
How do I know if options from a 1976 el camino will transfer and fit in my 1976 monte carlo?
In the 70's GM was notorious for simplicity. One size fits all, so it is highly likely that all the Monte Carlo options will fit onto the El Camino unless they are for behind the cab. To double check you will have to look at sales literature from both and compare option lists.
Sep 13, 2014 | Cars & Trucks
Low oil pressure on 2006 chevy monte carlo.
you do not state the figures for the low oil pressure. There are various reasons for low oil pressure in an engine.
One fact is correct, if you continue to use the vehicle with low oil pressure being developed, you will be looking at an engine replacement or full repair in the very near future.
Good luck.
Jan 31, 2011 | 2006 Chevrolet Monte Carlo
Stored 1985 chevy monte carlo 305 v8 a year ago ran perfect.tried to start today wants to start will not catch.any suggestions ?
BAD GAS!!! Empty tank, lines and and float. Get tarnish out with carb cleaner and put in fresh gas with chemical to dry lines of water/whatever. Replace fuel filter.
Nov 28, 2009 | 1985 Chevrolet Monte Carlo
1976 chevy monte carlo 350cid 4bbl cal. model.engine stops within 1 mile.idles high and gets real hot within 5 to 10 minutes of idling.having a hard time trying to time the engine.no vaccuum leaks...
Just a note to add the harmonic balancer tends to slip around giving you a false reading. i have had 3 of them on older cars that have done that. you may need to replace timing chain, and sprockets as well as the harmonic balancer.
As far as the over heating goes, i can only guess that maybe it is either the thermostat or the manifold work you had done sorry i couldnt be any more help
Sep 11, 2009 | Chevrolet Monte Carlo Cars & Trucks
Can't get belt off
just rotate the belt in a clock wise direction
Jul 15, 2009 | 1996 Chevrolet Beretta
Suspension
try the shocks first then see how it feels
Jun 07, 2009 | 1985 Chevrolet Monte Carlo
My check engine light came on
Take it to autozone and get a free dianostic check with a scan tool. The code will point you in the right direction to diagnos the problem.
Jun 05, 2009 | 2003 Chevrolet Monte Carlo
Need to replace all belts on my chevy monte carlo ss with a 305 engine and air condition
if it is a v-belt set up the alternator power steering pump and maybe the ac can be loosened and they pivot to take the belt off
Mar 29, 2009 | 1984 Chevrolet Monte Carlo
1976 76 Chevrolet Monte Carlo Light Bulb-1976 Chevrolet Logo
56 people viewed this question
Top GE Vehicle Parts & Accessories Experts
ray012965
ray gallant
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
