How do I reset the washing program ? I tried to change the washing cycle and it would not run. Now I cannot return to the original washing cycle.
The machine was operating well on my normal cycle. I then tried to change the cycle to a quick wash and it didn't work. I ended up pushing all the buttons with no result. I've now got it with just the "Start" button illuminated, but there is just a low hum from the machine and it does not start the programme.
    Sergeant:
  • 242 Answers
Unplug the power then plug it in again. Now select the program you wish to run and start it. Make sure the door is well shut.
Posted on Dec 03, 2014
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
During spin cycle machine runs for 20 sec then stops.After opening and closeing door it runs again for 20sec then stops.Tried re-arranging laundry for balance but still same problem.
Change the program on the machine and try , if the fault clears then it can be related to the program. However if the fault seems to continue it can be due to problems in the drive getting cut off. Check for any problems on the door switch, clean and set if in case there is loose connection that gets disturbed during spin and so resets.
Mar 09, 2016 | Washing Machines
Speed queed sc40 will not drain keeps washing
It sounds like your controls are malfunctioning -- getting stuck in one cycle. If the machine is old and uses an electromechanical timer control you'll have to replace it. If it uses modern electronic controls, try unplugging the machine from the power socket, waiting 5 minutes, and plugging it back in. Often that returns the controls to their original program. If that doesn't work, it's time for a service call.
Oct 07, 2014 | Washing Machines
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 11, 2011 | Washing Machines
Program selected ie 40c and washing machine starts. Appears to stop after the wash cycle, machine does not have water in it. The time which had moved down to around 48mins returns to start time 125mins....
It seems there is not accepting cold water on wash . The solenoid for the wash is probably open circuit. Check the solenoids with a meter for continuity. I bet you will find one open circuit. Then you can go get a new one and replace it. Might also be the pressure sensor failure, but that is not consistent with a successful rinse cycle. Make and model would have helped ..... Cheers
Mar 01, 2011 | Washing Machines
IT IS STUCK , IT JUST HUMMS ,CYCLE DOES NOT START
I PULLED THE DISHWASHER OUT FROM UNDER MY KITCHEN TOP. THEN TRIED IT AGAIN AND IT STARTED WORKING. WATER WAS ENTERING THE MACHINE AS IT SHOULD AND THE WHOLE CYCLE WAS COMPLETED FROM WASHING TO DRYING. BUT WITH THE ODD RATTLING SOUND NOT COOMING FROM DISHES. I ASSUME THE INLET PIPE WAS PROBABLY BENT THEREFORE BLOCKING WATER COMING IN BUT WHY NOW AFTER YEARS OF BEING IN THAT POSITION. THE OTHER THING I CHANGED WAS THE ELECTRIC SOCKET POINT- IE I PLUGGED IT IN SOMEWHERE ELSE BECAUSE MOVING IT MEANT THE LEAD COULD NOT REACH ORIGINAL SOCKET. HOPEFULLY WHEN I RETURN IT TO ORIGINAL POSITION EVERYTHING WILL BE WORKING. FUNNY THING HAPPENED THE WEEK BEFORE- MY WASHING MACHINE WAS STUCK IN MIDDLE OF A CYCLE . BUT STARTED WORKING THE FOLLOWING DAY. COULD IT BE MY ELECTRICITY PERHAPS - IE MY APPLIANCES ARE NOT RECEIVING ENOUGH CURRENT?
Dec 04, 2008 | Dishwashers
NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Sep 30, 2007 | Neff 24 in. S5456 Built-in Dishwasher
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
