Question about Simrad NX45 121 Display wBuiltIn Sounder_GPS Antenna
How do i put my marks into an nx40
Been through it can find how to create one while on the water but can,t enter one manually
Can i use a shop vac quiet series 2.0 model 86m200 w out a filter of any type to get up water and some funky stuff
You can do that but you absolutely shouldn't. The filter is what prevent particles from entering the motor and what creates a break for incoming water. That way a solid stream of vacuumed water doesn't go directly up the motor.
Dec 25, 2017 | Shop Vac Vacuums
What code do i enter after reset a casio te-2400 cashregister
There is no specific code. You need to create one based on your needs, currency type, country etc. In the programming manual, you'll see the table for creating a MAC (init) code. Run through the table to create the code and then input it during the init process. If you don't have your programming manual, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Jan 12, 2016 | Retail Supplies
How do I add or delete contacts
since you didnt specify the model i'm telling you how i do it on my s3.
creating contact 1
hit "phone".
select "keypad"
enter phonenr
click the "add to contacts"
click "create contact"
enter name and other information you want for the contact
click "save"
done
creating contacts 2
press "phone"
select "contacts"
press the "+" next to the search
enter contact information
press "save"
done
deleting contacts
press "phone"
select "contacts"
find the contact to delete and press down on it until a options menu appears.
select "delete"
you will be asked if you are sure you wanna delete the contact
press yes if you do. no if you do not
done
Dec 13, 2014 | Samsung Galaxy Cell Phones
How do I save a new waypoint on my garmin 76cx?
Hi!
From your User's Manual Page 7:
You can create waypoints using three methods. Press the Enter/Mark key while at a location, create a waypoint on the Map page or you can manually enter lat/lon coordinates.
TO MARK YOUR CURRENT LOCATION
Press and hold the ENTER/MARK key until the Mark Waypoint page appears. A default three-digit name and symbol will be assigned to the new waypoint. To accept the waypoint with the default information, simply select OK.
To change any information, select the appropriate field and press ENTER to open the on-screen keypad. After entering and confirming the information you wish to use for the waypoint, select OK.
CREATING WAYPOINTS USING THE MAP
On the MAP page, use the ROCKER to move the pointer to the map item you wish to mark.
Press and QUICKLY release ENTER/MARK to capture the pointer location and open the information page for the map item.
Select SAVE. If there is no information for this point, a prompt will appear saying "No map information at this point. Do you want to create a user waypoint here?". Select YES.
If you require a User's Manual, you can view/download it from:
http://www8.garmin.com/manuals/GPSMAP76Cx_OwnersManual.pdf
Hope this is helpful to you.
Good Luck!
Feb 27, 2011 | GPS
I forgot to add shipping fee to invoice. Payment has been received. How do I send another invoice for the shipping fees?
Hi there!
Unfortunately, you can't send another invoice through eBay but you can send another one through PayPal but you will need to have the buyer's phone number so contact the buyer first. And here's how you can send a manual paypal invoice:
Here's how you can create a manual invoice using your PayPal account:
1. Log in to your PayPal account.
2. Click Request Money.
3. Click Create a Money Request or Create an Invoice.
4. Enter the required information.
5. Click Continue.
6. Review the information and click Request Money to send a money request or Send Invoice to send an invoice.
You can also ask several people at the same time. Just enter their email addresses, separated by commas.
I hope this helps. Have a great day!
Serverbot Fixya help guru for eBay concerns bolerong_gago@yahoo.com
Sep 21, 2010 | eBay Auctions
Just need instructions to descale my Lavazza Blue coffee machine
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Sep 05, 2010 | Lavazza 2210
How do i add a link or button to my web-side
you can create a short cut on your desktop and access any time you need..
When you have a website that you visit often, its better to create a shortcut on desktop ragher than always searching for it Here is the step by step instruction on how to create website shortcut on desktop 1.Right click on empty space of the desktop 2.Navigate to NEW-> Shortcut
3.A shortcut wizard will open up You have to enter the URL ( website adress) of the website.You can type it manually or you can copy and paste it from address bar.
After entering the URL, Click Next, Enter the name of the shortcut.
Click Finish
Now you can see the short cut on the desktop. once you double click on it, it will take you to the website.
Jun 13, 2010 | Computers & Internet
Never fills up with water
This is caused by the drain hose being put to tight into the standpipe or the standpipe to low. The drain hose should be at least the height of the machine and should have an air space around it where it goes into the standpipe ( this is your drain pipe in your home). If it is to low water will run right out of the machine when it enters. If there is no air gap it will create a siphoning effect and drain your machine. If you need a manual try entering your model 3 at www.appliancehelponline.com. Not all models are available.
Jun 08, 2010 | Roper RAS8445KQ Top Load Washer
13 hex pairs
ok from your message i can understand that you have created 128bit WEP password..... i recommend you to use 64bitWEP password.... and in key1 i want you to enter only numbers manually instead of using HEX pairs....
in 128bitwep it will ask for 26 characters....you can also give a try by entering only numbers for it... still if you cant then go for 64bitwep and enter 10 characters(use only numbers).... this will resolve the issue....
Apr 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Entering map references manually
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Dec 01, 2008 | Garmin eTrex Legend GPS Receiver
Simrad NX45 121 Display wBuiltIn Sounder_GPS Antenna Logo
37 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
