I have ir 2016j indicating E805, what is the cause and the solution
Error code 805 on start
  • 128 Answers
The heat discharge cooling fan failed to function. Problem is usually resolved by replacing the bad fan motor assy. If not, the DC power supply is probably bad.
Posted on Dec 03, 2014
How do i fix Error E007 on Canon IR 2016j?
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Ir 400 error 805 002
Your connector is not good is connected to the DC control board. That connector is J112, which is located in top 3 of left to write.
Jun 12, 2012 | Canon imageRUNNER 400S Copier
Canon ir400 E0805-0014
Hi
this is not the same sub code but it's a start.
getfile.asp?rid=1258 September 27, 2002 getfile.asp?rid=3215 Product : imageRUNNER 330 / 400 Title : E805-0002 Error Code Error :
E805 with a 0002 Sub Code
Workaround :
This may be caused by a pinched wire that goes to connector J108 B-18 on the DC Controller. The wire was pinched to the frame near the riser to the DADF-A1 exit side hinge. Inspect the harness indicated by the arrow in the picture. getfile.asp?rid=4772 Canon USA, Inc. Systems & Technical Support Division
Dec 28, 2010 | Canon imageRUNNER 5570 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 21, 2009 | Canon imageRUNNER 400S Copier
Ir400s cannon i am getting error 805
if you can go to service mode check the sub code of E 805 (means one fan motor is not working properly )the sub code tells
which fan is faulty
Jun 15, 2009 | Canon imageRUNNER 400S Copier
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Error code
805 codes are usually associated with fixing exhaust fans not powering up. Usually due to a blown SMD (Surface Mount Device) fuse on the DC controller PCB.
Aug 29, 2008 | Canon imageRUNNER 400S Copier
k24674
