Please tell ATDC setting range of develop ineo 213
5 Suggested Answers
  • 4 Answers
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
Posted on Mar 13, 2008
  • 57 Answers
SOURCE: I have a Develop
C0F32: Faulty ATDC Sensor
Gently swing the IU in the horizontal
direction to even out developer
in the Developer Mixing Chamber.
Clean ATDC Sensor (UN1).
Change ATDC Sensor (UN1) and
developer.
Change Master Board (copier:
PWB-A).
Posted on Jul 08, 2011
firozsafeena
SOURCE: how will i reset maintenance m2 in my copier ineo 213?
Develop ineo 213
Posted on Oct 03, 2012
  • 487 Answers
SOURCE: I have a KONICA MINOLTA bizhub 7115, but I do not know the code developer ATDC - auto adjust, please let me know. thank you
Are you saying that you don't know what the code means?
Posted on Mar 09, 2015
What's your question?h how can i fix m2 in konica minota 213 ineo copier
Reset the drum and developer counters to zero, the replace the developer, and run the required TCR adjustment. Do NOT reset the counters then think you don't have to replace the drum and developer, because the copier uses the counters to determine voltages for certain parts inside the machine, reset counter and not replace the parts the copier thinks they are new when in fact they are old you get codes and bad copies.,
Feb 02, 2016 | Konica Office Equipment & Supplies
Code cof32 appears
cof32 is telling us that ATDC sensor is reading toner supply incorrectly, now this Toner Density Control sensor sits inside the developer unit of this machine, and toner is feed into it, where the atdc sensor reads the amount of toner that it has mixed with the developer and adjust it occording to level initally set when developer was first installed.
Developer can become old and not attract the toner any more
Toner can clog up and not be able to get to it
Developer can be spilt so it is no longer at right level.
Maybe it wont stir cause of something mechanical
Sensor rarely fails
or maybe the ATDC sensor needs to reset it's level (service f8)
not sure but ...Service mode stop 00 stop 01 then select F and 8
link to new dev
http://supplydepot.com/amazing/itemdesc.asp?ic=MIN8936416&eq=&Tp
Nov 05, 2007 | Minolta Di152 Laser Printer
The ATDC control voltage was within the range of 5.39V to 8.15V when function F8 is run.
Dec 03, 2014 | Office Equipment & Supplies
I can't share my printer ineo+351 i don't have the
You must press Utylity/Counter next open on screen admin setting. (Pass is 12345678) next network setting, IP setting and you can set IP address. If network (card, cable, switch or router) are OK you can print on your Develop. Driver you find on www.develop.de or http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
Nov 03, 2013 | Compatible Develop Ineo 300, Ineo 300,...
Erreur cof 32
ATDC sensor malfunction.Try to change the ATDC sensor gain adjustment value,increase or decrease.If the error persist you must be change the developer and the perform the F8(developer and ATDC semsor initialization).To reset please tell me the copier model.
Apr 01, 2013 | Konica Minolta Office Equipment & Supplies
Maintenance m2 appears my ineo 213 how can i remove it?
unless the drum and developer are replaced not a good idea to reset the counter. causes codes and image problems
Feb 07, 2012 | Minolta Office Equipment & Supplies
I have a Develop ineo 161, problem is erorr cof32, please give me advice how fix that terrible mistake
developer.
PWB-A).
Jul 07, 2011 | Office Equipment & Supplies
29 people viewed this question
k24674
jasbo
jasbo
