Question about Home Security
My sentry safe, number bx-887566, is stuck in the open position. The lock is engaged and the key won't turn. How do,I fix this??
  • 998 Answers
I did this on my own safe. Different brand but you can try. Somewhere on the door , look for a latch or pin or rod that you can push in.These are usually triggers that allow the lock to turn only when the door is closed. Somehow, you have locked it with the door open (as I did). Press in any of these and try turning the lock. It will be tricked into thinking the door is closed and allow you to turn the key. Good luck
Posted on Dec 03, 2014
3 Suggested Answers
SOURCE: I can't open my Sentry Safe (model #2100)
The problem is in the latch so one solution is to sit on the box, squeeze the latch and it opens. Voila!! Stupid R&D!
Posted on Aug 10, 2010
SOURCE: I have a Sentry Fireproof Safe (KS2100). Need to
You are supposed to apply downward pressure on the lid when you try to open it. See if that solves your problem.
Posted on Aug 12, 2010
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
Won open my sentry safe f3300 is stuck
The best way to break the rubber water proof seal is to push down on the left rear corner. That will pop open the front right corner need more help you can get my phone number here
Apr 03, 2013 | Sentry Fire Safe Waterproof Security File...
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
Aug 25, 2009 | Sentry Fireproof Safe
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Mar 16, 2009 | Sentry Fireproof Safe
My sentry safe
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
Feb 06, 2008 | Sentry Fireproof Safe
Home Security Logo
197 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
