Question about Sewing Machines
Where can i buy a Heilsa QCPS-28000 circuit board ?
Contacted Quality Craft, and they do not have it.
3 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: I need to replace the circuit board in my wifes
There are three circuit boards in the 7500. You should be able to get the correct board from any Janome dealer and if you need help installing it, I can help. It's very simple.
Posted on Aug 04, 2009
SOURCE: I need a new circuit board for a Memory Craft 7500 computerized sewing machine. Local dealer was no help. Do you have any suggestions of where I could purchase one?
check with these sites & ask them in a email about the part
sewvacdoctor.com
a1sewingmachines.com
Posted on Aug 14, 2012
I have no power going to my Janome memory craft 11000 it's as if a fuse has blown
The Janome Memory Craft 11000 does indeed have fuses on the main circuit board. Often, if one of the motors becomes overloaded, as is occasionally the case if thread gets bound up in the hook/bobbin area, it will blow one of the fuses, to prevent serious damage to the motors or mechanical parts.
They are not easily removed at home, and doing so would not be advised as you would be dealing with delicate electronics on a very expensive machine. I would recommend taking your machine to a Janome dealer to have it fixed. There are a few other possible problems, thought the fuse is most common, and it would be better to have it diagnosed by a technician.
Mar 11, 2015 | Janome Memory Craft 10000
Where do I find the fuse location on the Janome MC 6600P?
The fuse is on the inside side of the inner circuit board behind the front panel. There are 2 fuses, top is 3.15 amp and the botom 2.5 amp
Feb 13, 2012 | Janome Memory Craft 5700
Need fuses for janome 4000
You can get the fuse at Radio Shack. Part number 270-1065. It is a 3.15 amp 250 volt slow-blow fuse.
If you replace the fuse and it blows again, you need a new A circuit board part number 829606005.
Nov 03, 2010 | Janome Memory Craft 4000 Sewing Machine
Janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Mar 05, 2010 | Janome Memory Craft 9000 Computerized...
Need touchscreen backlight for merory craft 8000 janome new home
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Dec 09, 2009 | Janome Memory Craft 9000 Computerized...
I need to replace the circuit board in my wifes New Home Janome Memory Craft 7500. Where can I buy the circuit board and how do I install it
Aug 04, 2009 | Janome Memory Craft 9000 Computerized...
Memory Craft 8000 LED is not lighting up bright enough
This is getting to be a common problem on this machine.The only way to fix this problem is to take it to an Authorized Janome Dealer who can remove the circuit board, send it to Janome for a rebuild and reinstall it. Plan on spending more than $300 including the servicing that should be done at the same time. This is a good machine and it is worth the repair unless you just want a new one that is a little easier to use.
sewman7
Apr 07, 2009 | Janome Memory Craft 9000 Computerized...
I need a new circuit board for a new home memory craft 6000
the board which you require will only be provided with the janome service center. still you can check out this link  http://www.sewingmachines.com.au/janome9000.html
for more details on any other require ment or contact this link to ghet them the required fboard for you.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Janome/New Home Memory Craft 8000
I have a memory craft 8000 that gets a message stating "Stepping Motor Error". What can I do to try to fix it?
Oct 01, 2007 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
