Question about Hoover Washing Machines
How to remove the drain pump from my hoover washing machine
I HAVE CLEANED THE FILTER AND MADE SURE THERE IS NO BLOCKAGE IN THR DRAIN PIPE
    Master:
  • 514 Answers
Bend machine one side locate drain pump remove drain hoses, screws and pump, replaced with a new one
Posted on Dec 03, 2014
Why wont my Washing mwchine drain? Model #glws1339eco
Most of the time a washing machine wont drain is the pump has failed or got blocked , undo the pump filter at the bottom of your machine take out the drain pipe hose and drain into a bowl , when you unscrew the pump filter cap get a torch so you can see if there is a blockage around the fan , if so clean it , if you don't see any blockage the the need to take out the machine tilt it over and test the pump with a multimetre
Jun 24, 2017 | Washing Machines
What does the fault code E18 mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Zanussi 1250 washing machine FLS 1383 W does not drain
Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
Jun 20, 2013 | Zanussi Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
My machine wont drain or spin. if i maually empty, it will eventually start a wool wash but then says error e20 but filter is clean and no kinks or blockage in drain pipe. should i replace outlet pump?
Do the following.
1. Switch off the machine, unplug or disconnect the mains AC power to the machine and turn off the water supply to the machine.
2. Remove the filter access panel.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 13, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
The pump on my hoover washer hnf7148 has been changed but the problem persists. Water is still in the drum and it will not drain away. The control panel when the machine stos shows the door closed with...
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Jun 24, 2009 | Hoover Washing Machines
My Hoover 1100 washer/dryer goes through its washing cycles fine but sometimes stops at the draining point. I suspected drain blockage, pulled out the rubber pipe at the bottom and found 7 coins there last...
I suspect this could be a 10p pivoting in the entrance to the filter housing. To remove it tilt the machine back and take off the pipe which is attached to the pump. Feel inside the plastic pipe and remove it.If there is no blockage the pump may have been damaged and will have to be replaced.
do post back if further assistance required.
regards
Dec 04, 2008 | Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Error code 3
Error code 3 is a fault code related to draining you washing machine.
1. first check the drain pipe is not kinked or retricted.
2. Remove filter from washer and inspect for blockage.
3. Try blowing down the drain hole to release any foreign objects that may have become jammed.
Hope this Helps
Jun 26, 2008 | Hoover Washing Machines
Washing Machines Logo
59 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
