How do i Fix New Nonworking Belkin 8 outlet surge protector? Plugged in once, tripped the circuit breaker, now doesn;t work at all.
Tried plugging into other outlets, different buildings.. doesn't work. Google search for others that may have experienced similar issues, came across this suggestion to update drivers for this Belkin model #. http://www.driversguru.com/manufacturer/Belkin-pid-R%3E4191829%3E4191948%3E4198309 This link is a page long of downloads... Would you advise that I download all, then plug laptop to surge protector? OR Any other suggestions I can try? Thank you, Gem
    Top Expert:
  • Office Equip... Master
  • 51,348 Answers
Don't waste you time fixing a new faulty item
take it back for a refund
Posted on Jun 09, 2017
SOURCE: Canon mp830
When it wouldn't come back on after the electricity went off, I tried the suggested 20-minute rest for my Canon MP830. When I plugged the printer in again after 20 minutes, it was fine!
Posted on Aug 05, 2008
tumi001
  • 102 Answers
SOURCE: No Power to HP All-In-One 7310xi
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab102
Posted on Jul 17, 2009
  • 84 Answers
SOURCE: no power; tried moving plug to another outlet
try to replace the power Chord. after that also it retains same check the Switch mode power supply board inside the printer. if the power supply box externally available pl check the voltage of te power supply, Kindly feedback me
Posted on Aug 23, 2009
  • 21 Answers
SOURCE: While on-line this morning, our power went out.
Check for a reset button on back of unit near power supply.
Power outage not a problem however power surge is, get a surge protector
Posted on Feb 02, 2011
  • 884 Answers
SOURCE: How do i Fix New Nonworking Belkin 8 outlet surge protector? Plugged in once, tripped the circuit breaker, now doesn;t work at all.
Hi
The link you mention relates to Belkin's range of computer cards and network equipment. The drivers on this site will not help you at all since the Surge Protector is related only to the power supply to your machine. Its purpose is to prevent surges and dips in the electrical supply that might be harmful getting to your electronic equipment and damaging it. They require no drivers and have no means of applying them either.
If it blew the circuit breaker the first time you used it, and it doesn't work - anywhere - then its faulty. You mention that it is new, therefore don't make any attempt to repair it, open it or anything, just take it back to where you bought for replacement, since it was clearly not of "merchantable quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 03, 2014
Older home currently has 100 amp service. No problem if appliances are plugged into wall outlets. Microwave works if plugged into wall outlet.Trips quickly if plugged into UL Listed surge protector.
faulty surge protector
They are useless after one power surge and the breaker is probably reading the faulty earth leakage from the protector
logical that it the oven works anywhere but trips on the protector , then the protector is faulty
May 26, 2018 | Cars & Trucks
Hi
Cheers
Dec 03, 2014 | Computers & Internet
Belkin F9S820sp06 surge protector 8 outlet is new, but doesn't work when plugged in.
Look for a reset button. IF no button exists then you might (with it plugged in) turn it off and on a few times to see if it resets itself.
Dec 03, 2014 | Televison & Video
New Treadmill blows ciruit breaker when turned on.
have the new tread mill checked under warranty as it should not blow breakers from new
Feb 13, 2018 | Weslo Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
My Kenmore elite microwave is plugged into a surge protector and keep tripping the surge protector. I cannot use the microwave for more then a minute before it trips. Can you help
Your microwave is pulling more amps than the surge protector can handle. Remove the surge protector from the circuit and plug oven into wall outlet. Preferrably a GFCI circuit. Or you could puchase a surge protector with a higher amp tolerance.
Sep 04, 2011 | Microwave Ovens
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Out of Range
Do you have power to the base? I've seen this message on several cordless phones if the base is unplugged, the power brick has failed or the power adapter was plugged into a power strip (or surge protector) that has been turned off. It can also happen if the circuit breaker for that outlet has tripped.
First check that the power adapter is plugged into an outlet and the other end is plugged into the base. If the power brick is cold, check that the outlet has power by plugging in a different device (like a lamp) and turning that device on. If there is power, than you need to replace the power adapter or the entire phone (if you can't match the amperage output of the adapter). If there is no power at the outlet and the adapter is plugged directly into the wall outlet, check your circuit breaker for that outlet.
If you used a power strip or surge protector, check if it is on. For a surge protector, check if the surge protection circuit light is on. Replace bad surge protector.
I hope this helps.
(I have seen someone intentionally turn off a surge protector during an extended power outage and then fail to turn it back on after power returned. The individual forgot that they had turned things off before they called for assistance with their phone.)
Aug 17, 2017 | GE -25893GE3 Cordless Phone
k24674
jasbo
jasbo
