Question about Ovens
My Defy Gemini oven does not heat up beyond 80 degrees C when on conventional baking? What could be the problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 85 Answers
Check to see if the thermostat is plugged in under the cover inside left of door
Posted on Dec 03, 2014
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
Bottom oven does not work tim eflashes and gives 0-.-7
Child lock is activated go to http://www.defy.co.za/images/manuals/OPERATING%20PROCEDURE%20FOR%20DEFY%20GEMINI%20%20OVEN%20%206%20BUTTON%20CLOCK-TIMER.pdf last page.
Apr 12, 2014 | Ovens
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
Maytag gemini wiont go over 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 03, 2011 | Ovens
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Apr 01, 2009 | Ovens
Ovens Logo
275 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
