Question about ACCA Software Primus DCF
Is it hard to follow ACCA knowledge level while doing a job?
    Problem Solver:
  • 28 Answers
Hi Angel.
It depends on your definition of hard. Some person are able to work and learn in hectic environment (everything is busy and fast) and some person are only able to work in systematic, quite and organized environment.
But one thing about studying and working at the same time is : you will learn how to manage your time well. And you'll learn a lot of other things that can keep you going in life. Go ahead, take the ACCA, plus, i know it benefits you more (unless you've already made the calculations).
But bear in mind, i DO SUPPORT CONTINUOUS EDUCATION.
Posted on Dec 03, 2014
One front wheel is to one side other is straight it slipped gears up front .how do i re align
Get a wheel alignment done from a reputable tyre dealership - there is no way to do that job without correct tools and knowledge plus its very hard to get right manually
May 06, 2017 | Cars & Trucks
Just changed filters and replaced fluid engine light came on with codes P0755 and P0888 what do I do?
According to RepairPal.com: " Common Problems That Trigger the P0755 Code
  • Defective Shift Solenoid
  • Defective Shift Solenoid wiring or connector
  • Defective Valve Body
  • Dirty transmission fluid that restricts the hydraulic passages"
According to Infinity Help.com: "P0888 - TCM Power Relay Sense Circuit"
AccA
May 04, 2015 | Cars & Trucks
Drive shaft removal
Not to be a rude or mean but perhaps you have taken on a job that is over you level of experience with a watercraft or that requires special tools or shop equipment. My knowledge as an auto mechanic tells me that the trouble may be due to items that are pressed together hydraulically. My best "guess" is to buy a service manual for the watercraft, follow the tear down for the shaft and bearings in question.
Aug 19, 2014 | WSM 1992-1997 Kawasaki Ss 750 Cc Jet Ski...
Power steering pressure hose
The difficulty will be from limited work space and incorrect spanners to do the job Otherwise it can be done by any one with some mechanical knowledge.
Apr 28, 2013 | 2005 Hyundai Santa Fe
Is it hard to do valve job on your own?
Well there are two tasks at hand, first is removal of the head(s) and second is the actual valve job. head removal is not too big of a deal with some tools and a marginal amount of experience. I would recomend you use a good machine shop for the head rework.There are tools and knowledge you just will not have easy access to.
Jan 16, 2011 | 1991 Mitsubishi Mighty Max
Busted brake line in front of passenger rear tire. is this something a do-it-yourself guy can fix, or is this professional job only?
depending on you level of experience. If you are more than just a change your own oil person it should be possible. The biggest concern is whether or not you have the knowledge and ability to bleed the brakes after changing the line.
Dec 11, 2010 | 1993 Buick LeSabre
Where is ac fan blowermotor resistor located on a 1997 740il bmw
the blower motor resister is located in the center of the dash board right above the radio,you have to remove the top part of the dash board to get to it. Its not that hard. about a 35minute job if u have some car knowledge. you can go to bimmer forum and there u will find pics and instructions on how to do this job. good luck
slim
Aug 17, 2010 | 1997 BMW 7 Series
Chrysler 2001 - my brake pads are new, but someone said my rotors need to be changed. look like the Chrysler dealership that did my brake job, did a poor job. I have been having brake issues every...
replacing rotors is not an easy job but its not all that hard either, brake pads and calipers have to be removed, then the rotor, if your husband doesn't feel comfortable doing this i suggest you take it to a garage, they are your brakes after all :)
Feb 05, 2010 | Chrysler Town and Country Cars & Trucks
Is changing head gaskets on a 98 cadilacc difficult to do
TO CHANGE A HEAD GASKET IS SKILL LEVEL B MEANING YOU MUST HAVE BASIC KNOWLEDGE OF COMPLEX SYSTEMS.ITS A HARD JOB IF ITS YOUR FIRST TIME.THIS IS A DEALERSHIP JOB BECAUSE MANUFACTURER RECOMMENDS THAT THE ENTIRE POWERTRAIN BE REMOVED FROM THE VECHICLE.BEFORE REMOVING THE CYLINDER HEADS.
Nov 12, 2009 | 1998 Cadillac Seville
Blue shadows
coolant on picture tube need to be replaced hard job to do with not enough experience and knowledge , a tech can fixed 1 to 2 hour job with parts around 300.00 or less dependig on the tech.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Computers & Internet Logo
133 people viewed this question
Top ACCA Software Computers & Internet Experts
David Payne
David Payne
Are you an ACCA Software Computer and Internet Expert? Answer questions, earn points and help others
