Question about Kitchen Appliances - Others
I've got a Black and Decker bread maker that has been working fine until now. The dough won't mix- the paddle on The bottom of the pan spins freely, and the motor driven rotator seems to work fine as well, but somehow it is not mixing. Please help!
    Sergeant:
  • 242 Answers
The paddle has to lock onto the spindle. Is there dough in the hole in the paddle?
Posted on Dec 03, 2014
JSEhandyman
  • 368 Answers
SOURCE: Regal Ware Kitchen Pro K6746 bread maker
Hi johnandmb,
For Farberware parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/fw.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If they no longer support this part, I'd go hunting on eBay.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 24, 2009
SOURCE: My Black & Decker B900SC bread machine doesn't mix properly
Have you tried adding a bit more water to your mix? It sounds as if your dough is too dry. Sometimes, no matter how exact you follow directions, you have to compensate for variables of the machine. I have a similar problem with some of my bread mixes if I do not add an extra tbsp or two of water.
Posted on May 16, 2009
  • 14 Answers
SOURCE: The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Posted on Jul 03, 2009
  • 433 Answers
SOURCE: I have the Black and Decker All-In-One Deluxe
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Posted on Apr 22, 2010
  • 433 Answers
SOURCE: I have a Regal bread maker K6773. At the bottom
Hi..That assembly is part of the sealed bearing in the bottom of the pan. That sealed bearing allows the shaft and paddle to turn freely. Unfortunately Regal stopped making bread machines and parts several years ago so the chances of you finding a replacement is rare. Hank
Posted on Sep 21, 2010
Testimonial: "The answer I received is exactly what I needed to know. I appreciate the response."
The paddle keeps coming off during mixing and leaving a black stain in the dough
Hi, The sealed bearing located on the bottom of the bread pan has failed. This bearing is sealed with lubricant to allow the paddle shaft to spin easily. The black stain you see is the lubricating grease. You need a new bread pan. Hank
Jan 22, 2011 | Breadman TR2500BC Bread Maker
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a...
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Nov 11, 2010 | Panasonic SD-YD250 Bread Maker
I have a Regal bread maker K6773. At the bottom of the drive shaft in the bread pan is a tan rubber gasket and below that was a black rubber gasket that has completely disintegrated and ended up mixed up...
Sep 21, 2010 | Regal Ware Kitchen Appliances - Others
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
Apr 21, 2010 | Black & Decker Bread Machine
The machine does not rotate, I mean it does not mix the dough, the sound is on of rotating but it doesnt move on.
Take the bread pan and paddle out of the machine and see it you can spin the paddle freely by hand. If no, then the sealed bearing is frozen or broken. If yes keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is spinning. If no then the belt fell off or snapped, or the motor is broken. Haank
Jan 04, 2010 | Black & Decker B2300 Bread Machine
The dough made by my B2000 Break Maker has black contaminations coming from the paddle shaft. The shaft is quite loose and can be pushed up and down easily. Any help or advice on how to deal with this will...
That contamination seems to be oil from the lubricated bearing at the bottom of the bread pan. This bearing is factory sealed, but the seal and the bearing is broken or worn causing the shaft to move freely.
Unfortunately there is no fix and the pan must be replaced.
Hank
Sep 07, 2009 | Black & Decker B2000 Bread Maker
My Black and Decker All in One Automatic breadmaker seemed to be working fine. It was making the right sounds but when it finished the bread was not mixed. The yeast was still on top with the flour and the...
Empty the bread pan and clean it out. Put the pan and paddle back in the machine but do not add ingredients. Start the bread cycle and look in the window (or lift the lid) during the mixing cycle. You should see the paddle spinning around.. If not you probably need a new belt.
Hank
Jul 27, 2009 | Kitchen Appliances - Others
The machine bogs down when mixing the dough for bread
You should be using a dough Hook not paddle I have a Kitchenaid stand mixer and it uses a hook for dough paddles offer too much resistance for dough.
Apr 02, 2017 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
109 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
